Posts: 69 |
Has the AGSF32PPM been discontinued? I got some plugs from the dealership I work for and he gave me AGSF32FM plugs. He said they are a new replacement of the old plug. I guess these are "fine wire" single platinum plugs. I have read some people having bucking issues with these plugs so I did not install them. I asked the parts manager to get me the AGSF32PPM plugs, but he said they were not available anymore. I guess I will be going with the Autolite APP104 plugs, which I hear are the same as the AGSF32PPM without the coating on the threads? If anyone has any more information on these plugs, I would appreciate it.
'99 SVT Contour
Tropic Green
Stock
Posts: 228 |
I had those FM plugs as a replacement for the PPM. I'm using them right now and no problems for three months by now.
Pablo Quintana
98 SE Sport Contour
Honduras, Central America
Posts: 4,714 |
Any plug that's not double-platinum will have problems eventually. For me it took four months for splitfire plugs to begin to show signs of premature wear (hesitation at 3000+ rpm and 80+ mph). I switched to Autolite APP764 with no problems since (over one year now), but someone (DemonSVT?) mentioned that there is another Autolite plug that has the coating you're referring to. I believe the APP764 does not, but I'm not sure.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 9,602 |
AGSF32FM's are SINGLE platinum. Expect to change them in "roughly" 1/3 the time.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,475 |
Originally posted by DemonSVT: AGSF32FM's are SINGLE platinum. Expect to change them in "roughly" 1/3 the time.
Hmmm, I think those are the ones I might've gotten from the dealer ...
About how long would "1/3 the time" be?
Posts: 69 |
So the AGSF32PPM is not available any more?
'99 SVT Contour
Tropic Green
Stock
Posts: 509 |
I don't think that the double plat's are discontinued, but Ford has changed the spec for our car's to the fine wire plug according to the dealership.
I used the Bosch +4's which eventually started misfiring, and now I'm using Autolite APP764's with very good results.
don't drink and drive.
Posts: 69 |
What's the difference between the APP104 and APP764?
'99 SVT Contour
Tropic Green
Stock
Posts: 1,616 |
Originally posted by SVTmania: What's the difference between the APP104 and APP764?
About 660....
Posts: 9,602 |
Heat range.
764's are the plugs you want to use.
104's are 1 step colder.
2000 SVT #674
