Page 9 of 12 1 2 7 8 9 10 11 12
#787700 11/05/03 10:49 PM
"Absolut Rara."
"Absolut Rara."
1. This thread has turned into a pissing contest, if it doesn't turn around, I'll lock it.
2. Travis, you've thrown out some crap and have made no attempt to defend it technically, only proceeded to start a pissing match with the forum regulars. I consider this trolling, and that puts you on thin ice. Get back on topic, and bring more tech than flawed assumptions, or go away.
3. Stazi, just let it go. Stick to the tech.
Balance is the Key. rarasvt@comcast.net
#787701 11/05/03 10:49 PM
O
O
My roomate has an S4. 2.7L TT. Turbo's are TINY ont he thing. But you wanna talk about a small engine bay, look at one of those
Fast Cheap reliable Pick two
#787702 11/05/03 10:54 PM
"Absolut Rara."
"Absolut Rara."
and one other thing, Travis, my four year old nephew has better spelling and grammar than you do; this makes you look like foolish, and makes anything you post less believable regardless of what it is. I suggest making an effort to making your posts a bit more readable if you wish to be taken more seriously. But of course, actual tech is a pre-requisite before that will help anyway.
#787703 11/05/03 11:38 PM
Ok yes lets go back to the tech and ill try harder to become more clear in what im saying.
Ok regaurdless of whether you can package it or not lets talk about the ability of the seperate systems to make power.
This is my argument for 2 turbo`s.
Advantages:
The turbo headers are easier to make
By using 2 turbo`s exhaust header manifold design is improved. Because heat loss is kept low. Therefore the boost threshold is lower with the same a/r.
By the additional improvement in exhaust header manifold design a higher a/r can be used while maintaining the boost threshold at its current level which causes less tip.
In theory This will produce more power by allowing more radical cams and port work without reversion becoming a problem.
My argument for the exducer bore is made by this math work I completed.
Showing at 750 cfm (2) 2 inch pipes will see 286 ft per second gas velocitiy.
It would take a 2 and 7/8 inch ID pipe to flow the same amount of air at a slightly lower velocity 277 ft per second.
So the exducer bore on a single turbo would have to be quite large to flow the same amount with the same amount of pressure drop as the 2 smaller turbo`s.
Disadvantages
Cost if you go with new turbo`s
Sizing 2 turbo`s appropriatly for the application could be hard.
Extra complexity at controlling wastegates and making sure water/oiling lines get to where they are suppose to go.
Extra intake pipes and intercooler piping and intercooler modifications.
Single turbo:
Advantages
Simple
Cheaper
Would be very close to 2 turbo`s in performance *debatable
You can use a huge turbo I mapped out and found a t70 would work last night if you were going after like 25 pounds of boost
So bus turbo`s from junkyards are fair play here and that means cheap.
Disadvantages
Debatibly you could drag out more power from a twin turbo system.
Header is hard to make and has more areas that could fail. Its also less efficient. There is alot more surface area and bends before the turbo to cause heatloss and turbulence.
Turbo sizing on this side of the scale could be hard to get just right depending on desired rpm range.
You would have to use a large expensive external waste gate for that much flow which is harder to control then 2 smaller wastegates. So low speed could be more of a hassle.
Ex-cat cams dealer. Today we do motor mounts.. Tommorow. Intake manifolds
#787704 11/06/03 02:12 AM
I also done some numbers on compressor maps and for a high output 3 l running 22 psi I came up with these numbers
T66 (best matched compressor)
70% @ 7300 139 c* after turbo
76% @ 6000 129 c
76% @ 5000 129 c
74% @ 4500 132 c
Compared to the closest compressor for a twin turbo setup
T-3 60 series trim
69% @ 7300 140* (at the high end of compressor map)
73% @ 6000 134*
70% @ 5000 139*
67% @ 4500 144* (surge line)
Through the testing range of the engine they both would be pretty much the same with an intercooler.
With less boost pressure for street driving the dual turbo efficiency goes up as it drops more towards the center of the graph and the t66 goes down as it drops towards the bottem of the graph.
So the twin turbo would have a couple horsepower through the midrange over the single turbo from a stand point of just compressor maps and the single would have it in top end.
The twin turbo`s have a maximum combined flow of 62 pounds of air and the the t66 has a much higher 72 pounds of air
You could debatibly go with the t64 its smaller and would offer more midrange but top end efficiency wouldnt be as high. A trade off between the 2.
This is only on the compressor side though. My previous statement stands.
So the twin turbo setup would give you hotter temps through the topend. The single hotter temps through the midrange.
Id also like to add that beyond 22 psi there is not a good match through standard compressor maps for the twin turbo setup. Where as the the t66 has alot of room to grow. About 5 more psi across the board.
2 gt 32`s with a 52 trim would be better then Any of them by far. But who has 6000 dollars for 2 turbos?
#787705 11/06/03 03:59 AM
"Absolut Rara."
"Absolut Rara."
Oh man, where to start . . . At the beginning I suppose . . .
you don't seem to get it do you? This right here is the crux of the matter. The whole context here is turbocharger(s) applied to the duratec engine in the CDW27 platform.
There is no place to put the second turbo, plain and simple. Let's pretend you find a place anyway after relocating or removing all sorts of stuff, its still not gonna be in a place that allows you to run decent exhaust manifolds (ie short).
First, this argument is inane (yes that is spelled correctly, go look it up) because both layouts can be made to make equivalent power on this size engine, it is all in proper sizing for the application and proper tuning. Minor efficiency differences can even be accomodated for.
Hmm, I actually had responded to a bunch of your stuff, and ended up deleting it just now, becuase I realized that beyond what I said above, I kept saying the same thing; Virtually everything you say is contingent upon some pretty big assumptions about the package and the setup, most of which don't even apply in the case of the contour. You keep forgetting that this is a discussion about fitting a turbo or turbos to a Contour not a general single vs. twin discussion; I already responded previously with my general views on twin vs. single.
On to your second recent post, you compare a single vs. a twin with specific turbos.
First:
You do realize that this sort of setup would potentially be in the neighborhood of ~500hp at the crank? Not exactly the sort of power that could be handled by a contour transmission or chassis. Plus if someone has the cash to be dumping into a duratec to get to those levels reliably, do you really think its going to be in a FWD contour????? Let's try to be at least remotely realistic. But then again, you obviously have sized this stuff in search of the dyno queen of the year award.
Second, your "match" of a T66 compressor is ridiculous, anything under 4500-5000rpm rides the surge limit; I don't know much about you, but eating the compressor wheel because of constant surge doesn't sound fun to me. This also points to your poor choice of a 60 trim T3 for the twin setup, another serious surge problem.
So first, you choose an output level that no available transmission or chassis can support safely, and the engine block is even unknown at that level; and this even all assumes a complete rebuild using all forged internals and a custom forged crank. Second, you size everything such that it would be nothing but a dyno queen, certainly not something I would consider fun.
Peak Power is not the only thing that one should worry about on a street car.
#787706 11/06/03 06:15 AM
I'm sorry, Rara, but the irony was soooo thick here, I had to point it out.
'99 SVT Contour #535/2760, born 11/30/98. Toreador Red / Prairie Tan Wife's car: '00 Saturn LS2. Dk. Toreador Red (no joke) / Graphite Sunday Bruiser: '67 Camaro rs/SS350 4 spd. Ermine White / Custom Yellow
#787707 11/06/03 07:09 AM
O
O
Hey guys, I've been gone for a couple of days, what did I miss? And why is there urine all over the floor?
Contour--It will make a master mechanic out of you! 95 LX MTX Bolt-ons 95 Neon SOHC ATX 77 Dodge Powerwagon-more displacement than my Neon, Contour, and wife's Saturn---combined!
#787708 11/06/03 07:17 AM
please lock Rara, this ain't worth anybody's time. . .
though fun to read, just drivel. . .that is, what he writes, i take what you and the staz miester write to the highest. . .(as expected). . .
#787709 11/06/03 01:35 PM
Advantages:
These statements are enough for me to tell you to "shut the hell up".
First look at the top of this page, what does it say?
I'll help you: Contour Enthusiasts Group.
Moving on that means, yes, we're talking about the CDW27 platform - i.e. Contour, Mystique and yes, Cougar.
From there we have an established a packaging envelope (I'll break that down for your thick skull - that means "engine bay", chassis and suspension).
So now, I think we know what we're dealing with; the initial question of fitting two turbos to a Duratec equipped CDW27.
When the inital question was posed, almost instantly an answer was proferred; i.e. that there is simply NO F'ING ROOM for two of them. Thus your first statement is null and void.
What do I mean by that?
Regardless of how easy it is to fabricate two shorty 3-1 headers, that fact of the matter is that you CANNOT package a turbo between the rear bank of the Duratec and the firewall and other mechanical components (steering rack, intermediate shaft and subframe).
Second, with thick enough pipes with a low conductivity (i.e. Stainless Steel), the heat loss to one single turbo is low enough not to affect boost threshold, due to the fact that the turbo is sized APPROPRIATELY to allow for quick spool-up. In this case a T28 with GT center cartridge for the 2.5L Duratec, or a T3/T4 with and A/R ratio small enough to provide fast spool-up yet not constrict the exhaust flow, for the 3L Duratec. Which, I might add, has been sized approriately, for the 3L kit, from SF.
Regardless of what I have just said, YOUR turbine selection tells me, and Rara, that boost threshold and spool-up speed of little importance to you as boost would not be achieved until at least 4000rpm, which for a streetable vehicle (NOT A DRAG CAR), is pointless. The drivability of such a setup would be so "on-off" that the tractibility would be compromised and for anything but drag racing, it would be redundant. And like I said earlier, putting down anything more than 450hp will likely grenade even the toughest MTX-75,. But say you could, you would never be able to control such a torque spike to launch a Contour properly. And I can tell you've never tried to drag race a Contour as it is one of the worst cars for this form of racing due to it's weight distribution and suspension setup.
If these arguments aren't enough to make you realise that your constant blabbering is pointless, then I suggest you see a physician as it is aparent that you suffer from AADD (Adult (at a stretch in your case) Attention Deficit Disorder).
