Page 6 of 12 1 2 4 5 6 7 8 11 12
#787670 11/05/03 07:49 AM
SVT_AJ Offline OP
good point. there are advantages to both set ups. it all depends on what your trying to acomplish. while i have no doubt that a twin turbo set up will work in the contour, i don't care enough to argue about. i'll probubly just go single turbo so i don't have to think as much. if i build my 3.0L well enough it should be fun.
#787671 11/05/03 01:28 PM
Fact of the matter is that this all boils down to is: real estate. Why don't you shut your mouth for 2 seconds and TAKE A LOOK at a Contour engine bay (w/duratec). There's no fuggen room for two turbos plain and simple.
For example, from the factory (and on the SF kit) the rear manifold goes between the R/H intermediate shaft and the block simply because there is not enough room between the firewall, steering rack, subframe and the engine block to do it any different. Thus putting a turbo there is basically impossible, short of notching the firewall and removing your steering rack and part or your subframe too, or maybe mounting it in the passenger seat! But I guess steering is overrated for most drag racers so - what the hell!
Secondly, lets ssay somehow you fit a turbo for the rear bank back there (and lack of airflow doesn't kill it in the process). No you want (by your theories) to mount the front bank turbo, about the same distance away from the front banks exhaust ports, as the rear - OK, that puts the turbo IN the radiator. Hey - cooling's overated, so lets ditch the radiator.
Finally you'll need to route air intakes and discharges to both of these turbos and back again to the throttle body - oh wait you'll probably want to mount a Skyline FMIC too - well, I guess now you can seeing as you don't have a radiator anymore.
People like you who obviously haven't investigated what they are talking about - and then come on here and start talking like a crackhead - irritate me.
Ah what the hell, do what you want - I've seen people likeyourself come and go before. Sure you may have some knowledge of turbo chargers but your common sense is missing. Typical book-smart syndrome.
Stubborn assclown..........
#787672 11/05/03 01:55 PM
Arg im an auzzie actually youll probably be pleased to know im going to be running an autronic from the great land downunder. You gotta be bringing sky lines into this.. Im gunna be able to kill them in the quarter anyway once im done
Ex-cat cams dealer. Today we do motor mounts.. Tommorow. Intake manifolds
#787673 11/05/03 02:05 PM
Lern tu spel...
Nice comeback I'm hurt.
Killing Skylines in a Contour - your dillusional. In the off chance you're able to put 450hp to the ground (which I tout as being next to impossible with the MTX-75 and the Contour chassis/suspension). You're still going to be killed by Skyline. 450hp is peanuts on the RB26DETT.
Like Ren Hoëk once said, "Stimpy, you're wealth of ignorance astounds me!".
Someone ban this troll
#787674 11/05/03 02:08 PM
Yea guess i should... better off not and sayin i did though. Unless you just cant read my post why [censored]
#787675 11/05/03 02:14 PM
Is this English?
#787676 11/05/03 04:33 PM
Is it really this important to insult my word knowledge/percision.accuracy rather sorry for my misuse of percision. had i not made the correction you obviously couldnt of figured out what i ment... This thread seems to have ran its grounds mayby someone could lock
#787677 11/05/03 04:46 PM
How can you be taken seriously when:
A) You can't spell worth a sh!t.
B) Grammar obviously is also a problem for you.
C) You spout off unsupported theories and uncorroborated facts.
D) You have no apparent knowledge of the mechanical workings and consequential limitations of the Contour's drivetrain and chassis/suspension.
E)You couldn't pick out the differences between a Contour's engine bay and a jelly donut.
What's next? Are you going to claim you invented the question mark?
I would rather see you banned for talking nonsense, rather than see this thread locked.
Then if you could pass an IQ test score or 120, perhaps we'd let you back in.
#787678 11/05/03 05:25 PM
Okkkk... you can goto http://home.earthlink.net/~adrenilin/Index.htm I built an all motor zetec that did THAT to the diffrential I really think i know what the [censored] an mtx 75 is how it works and what it does. No i dont know what a contour engine compartment looks like. I am however interested in the knowledge that the people have on here about the 3l. You can get the hell of my back and shove it up your ass if you dont like what i have to say. Im an experienced engine builder and was making early 14 second passes on that engine. (14.19) (2.078 60 foot)
I would like to know exactly where your knowledge base comes from and just exactly why you think your intelligence level is soooooooo much higher then mine.
#787679 11/05/03 05:34 PM
