Page 5 of 12 1 2 3 4 5 6 7 11 12
#787660 11/05/03 02:10 AM
"Absolut Rara."
"Absolut Rara."
you know, I was seriously going to put together one of my patented all-inclusive replies, but its really a waste of time at this point.
The crux of the matter on a contour V6 setup is where could you possibly package the second turbo (ie the turbo for the rear bank)????
Perhaps I will get frustrated by this ridiculous discussion again later and come up with a full response.
Balance is the Key. rarasvt@comcast.net
#787661 11/05/03 02:21 AM
Originally posted by SVT_AJ:
theres room, you just have to be inventive. theres tons of room if you wanna try driving with no power steering. j/k
i'm still debating to try it or not.
Try it,, and when you run outta money and still don't have two turbos on your car, don't tell us you weren't warned.
#787662 11/05/03 03:17 AM
Oh common infamous moderator who smites all. I would really enjoy your input into all this.. If im so ****ing stupid how about you prove it
Ex-cat cams dealer. Today we do motor mounts.. Tommorow. Intake manifolds
#787663 11/05/03 03:23 AM
"Absolut Rara."
"Absolut Rara."
First answer my question about where you would put it.
IMHO that is the main reason for not bothering doing a twin setup, as either a single or twin could be sized for a duratec for the same performance.
#787664 11/05/03 03:44 AM
Well its going in a focus. Theres plunty of room under there... but i debate FI over here in contour forums seeing how there arnt many 3 l fuckus`s running around
#787665 11/05/03 03:47 AM
H
H
it has been done. on a noble. unfortunately in the tour it wont fit.
#787666 11/05/03 03:55 AM
Well of course it'll fit in a car with more engine bay room,, now as what would be best for a duratec, I'd still go with a single turbo, though true either single or twin could be tuned to perform about the same, just twin costs more and is more work. Also, most drag cars w/ turbos use a single turbo... i wonder why
#787667 11/05/03 04:17 AM
Most drag cars are inlines... those that arnt are old school kids that dont know anybetter... twin turb grand national... i seen a dyno for one the other day.. 836 horsepower to the wheels. Even on prostock v8`s (302 -351 displacements atleast) are still running singles.. But its completely on unstreetable application i seen a diagram by nasa a couple of months back stating that if you had primaries long enough (50 inches) you can run alot of overlap without reversion becoming a problem. Plus they use such high tech insulations that having the turbo`s that close to the head doesnt help. There isnt any heat loss anyways. Not to mention heat wraps and what not that they pile ontop of their coatings all this cuts down on reliability of teh manifolds. You wouldnt want a setup like that anyways unless you had a 2000 rpm idle with overlap that huge. (100 degrees or more) and a turbo that big.
I keep thinking that seperating the exhaust pulses has a good benifit though because they even do it on turbo housings Making 2 diffrent inlets from 1 bank. apparently by splitting the pulses up they arnt diluted as much. besides at that power level you would have to buy 2 massive turbo`s instead of 1 one god massive turbo. 2 turbo`s each capable of a 1000 horsepower would cost you some major dollars. where as you can pick up a gt 60 for like 4000 thousand. Instead of 2 gt 42(i think they are) for like 3500. I know there is obviously an advantage, everywhere iv read and everywhere iv seen a twin turb application is more durable and has the potention to make more power then a single because your splitting up the heat that each turbo has to endure and the heat the flange has to endure. The turbine housing its self and your increasing exhaust flow. I dunno I plan on having my build up rolling around in spring. And we`ll have to pit the dyno numbers against the dyno numbers of the biggest single when i roll it out put some miles on it and pin it to a dyno.
#787668 11/05/03 04:20 AM
"Absolut Rara."
"Absolut Rara."
Focus is a completely different story, which conveniently wasn't the story being discussed here.
Back to the, so far all of your arguments seem to basically hinge around peak flow through the turbine housing, and how two small turbos have more flow capability than a single, larger unit. That point is completely irrelevant, as on a single, I have the option of using a larger turbine housing to reach the same equivalent flow capacity, and consequently achieve a similar TIP as whatever you get for your twin sizing. On the examples that have been discussed, I can go anywhere from the smallest T3 housing (.48 is the smallest I'm familiar with) to a T04 housing large enough that a 3.0L would be bouncing off the rev limiter to even spool it at all.
Further, your statement that you don't need to reach peak boost until 4500rpm, while it may be fine for you, is horribly flawed in assuming that is what everyone else would want. Personally I'm not a big fan of a dyno queen; I would much prefer a well balanced system that is useful under everyday conditions, in that it has a reasonable boost threshold, and doesn't choke itself off until beyond the useful rpm range. I'm very much an area under the curve guy, not a peak numbers guy.
A single turbo is inherently more efficient than a twin setup, all other things being equal, that is a fact.
IMHO, there are three key reasons to consider a twin turbo over a single.
1. Package reasons. On many V-type engine applications, a twin setup will allow much better header design. Unfortunately, the contour is not one of these applications, as there is barely enough room between the block and the dash panel for the existing manifold, let alone a turbo for the rear bank.
Fwiw, on my Cobra, I have chosen to run a twin turbo setup for package reasons (mostly anyway) as I can mount the turbos very close to the block on short manifolds, without relocating a large number of components. A single, while quite "doable" on my mustang requires a somewhat compromised header design due to the long assymetric crossover required, and requires relocation of several components that i dont want to move right now.
2. Turbo Sizing. In some cases a proper single size may not be readily available (or at all) This can be the case in many larger engine designs. This also somewhat applies to my own project, as I had several T3's "laying around" to use, and no appropriate T4 handy.
As a side note, my case is an excellent example of considering the entire system when sizing your turbos. In my case, some T3/T4 hybrids would have been an ideal choice for maximum power and efficiency that could be had out of a 302; but since I have no intention of even cracking the valve covers until I'm ready to build a completely new motor, the T3's I do have are capable of supporting enough power to split my block in half (its been done on several T3 assisted 5.0L engines that I know of) So steping up to T4 compressors was completely unecessary. Of course this is all aside fromt he fact that a T4 cold side won't fit between the block and the framerail on my car anyway (heck one commercial kit required a frame notch plate to fit a GT28 in there . . .)
3. This third point is very simple: Pimp factor. It sounds way cooler to say "my car is twin turbo" rather than "I have a single turbo on my car"
Sadly, this is truly the reason most people even mention or think of twin turbos "OMG, he's got TWO turbos, that must make waaaay more power than just one".
Travis, I will give you this, a good bit of your theory is correct (most of it actually, though there are a few things in your posts that I hope are just accidental mis-statements) but your application is flawed, especially in your comparisons.
#787669 11/05/03 04:26 AM
You'd blow a duratec before any single or twin turbo setup could outdo the other.
