Posts: 494 |
Hi,
My local audio retailer has some MTX Thunder 10" subs for $39 each. I don't know much about them, other than the fact that they're very inexpensive. They seem to me to be sorta junky, but I wanted some opinions to verify my hunch.
They are rated at 200w max, which as far as I know would be more than enough for my listening tastes and listening levels. I plan to run a sub in a small enclosed box (no band-pass or port) so that I can get a nice, tight bass sound.
There are also some pioneer subs on sale for $89 each (10", model TS-w254c). Rated at 500w max. If any of you have some feedback about these subs, please let me know -- it would be much appreciated, as the sale isn't on forever!
Thanks again, Brian
1998 Mystique LS V6 ATX - Satin Green/Grey Leather Moonroof - Ford Remote Starting System 885s for fogs - Fogs with Parks JVC KD-SH99 MP3 - Pioneer TS-A6865s in the doors JVC 12-Disc Changer "Sometimes I'm good, but when I'm bad, I'm even better."
Posts: 86 |
Try to stay away from ten inch woofers if you want some serious kick. I have 2 10" rockford fosgate subs and there are ok but Im setting up to pick up some 12" Kickers or 12" rockfords. It all depends on your listening pleasure. I would go with 12's.
Posts: 494 |
I guess John brought up an interesting point -- my musical taste.
I listen, mostly, to jazz, rock, and some hard rock (metallica, for example).
I'm not looking for bass that shakes the car, just that fills the car with a nice low sound. I don't want to eat up too much trunk space, so I was thinking either a single 10 or 12 in a small box.
Brian
Posts: 57 |
Get a Kicker L7 Solobaric 10in' square sub. I have that and a Kicker amp in my car and it sounds really good.
Street-Concepts Contour
Posts: 450 |
I had 3 jl 10w3's for my last system and they hit very hard tight and accurate. were installed in a 2.18 cubic ft common chamber enclosure. I had a crossfire 1000d on them and was able to do a consistant 145.5 db at the windshield as well as have crystal clear sound quality
Posts: 86 |
I listen to the same music you do but i like the hip hop that the teenagers are calling it :rolleyes: With hard rock like Korn Naptallica and stuff like that 2 10" inch sub should do you just fine. Try to get some good quality ones though because if you pump it as much as i do you will go through cones like they are water. Good luck....Keep us posted
Posts: 1,268 |
I've heard the MTX 10s you mentioned in a ported box. They were barely able to put out MIDbass with any volume. I would stay away from those.
-Ken V. psycho_bass@hotmail.com My Car
Posts: 8,142 |
I've got just the sub for you!
ummm...maybe not. it looks like they are sold out...damnit.
let me try again....
Posts: 4,585 |
Dave, I was thinking the Credence 10" at PE, but already did a search this morning.
Jazz, how much did you want to spend of your sub(s) and how space do you want to take up in your trunk?
Posts: 2,587 |
I'll sell you my 12" Clarion! The VC is warped and it makes a scratching noise when it's running, but it still works and you can have it for $500 and I'll even throw in the box!
1996 Contour "Mean Green" (99-02) 2002 Malibu Blue Focus ZX5 - something to hold the PB 15...
