Posts: 17 |
1996 Contour GL Zetec A/T 118000 T-RED
Posts: 21,653 |
Throttle position sensor, attached to the throttle body by two really tight screws.  I guess it senses how far the throttle is open/closed.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: Throttle position sensor, attached to the throttle body by two really tight screws. I guess it senses how far the throttle is open/closed.
It also determines where the car shifts (ATX). I accidently left the connector off and drove the car...couldn't understand why the car was staying in gear...kind of like throttle hang.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,459 |
Originally posted by Kremithefrog: attached to the throttle body by two really tight screws.
Hey, I noticed that too....those rascals were next to impossible to get loose. I finally put a screwdriver bit in the end of a ratchet, and got it to break loose.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 6,280 |
Make sure you put a cover sheet on your next TPS report. You know we're using the new cover sheets, right? Did you get the memo?
Posts: 1,444 |
heh heh, office space...good ole tps reports.
Posts: 85 |
If your CEL is telling you to replace the TPS try cleaning the MAF gently with alcohol and Q-tips first. Mine read TPS and it wasnt that at all..
