Posts: 147 |
what is a sufficient ground in my trunk for my amp?
Posts: 4,714 |
You need to sand down a spot to bare metal. On my trunk, you can see what I did here:  This was using a Stinger grounding mount. I sanded down to bare metal, mounted using some self-tapping sheet metal screws, and attached the ground cable (the brown cable in the picture there).
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 3,264 |
Just use one of the big hex screws holding your seat belt latches in place, sand the area the ground connection will come in contact with and reinsert the big hex screw.
Posts: 79 |
got a pic of that seat belt latch's placement?
I'm lost on where that would be.
96 Contour LX ATX
Clarion DB625MP
2 "5x7" infinity kappa's in front
2 stockers in back
1 JBL GT 1200D 12'
1 jensen xa2150 pushing the sub
*upgrades comin soon
Posts: 2,446 |
I think he's refering to the middle seat beat mount that is in the rear deck. I and as welll as many others have used one of he boldts to the taillights, works great for me.
HTH
Posts: 21,653 |
Originally posted by FLCEGkid: I think he's refering to the middle seat beat mount that is in the rear deck. I and as welll as many others have used one of he boldts to the taillights, works great for me.
HTH
Me included,, though maybe that will change,,, may look cleaner in a different spot, depending on how Eric designs my trunkal area. Please do it,, pleazzzzze.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,076 |
He's referring to the bolts that hold the bottom of the seatbelts down, they are under the side cushions...just grab the cushion as far underneith as you can and give it a quick tug upwards.. it will pop right out. If you don't want to mess with that pull out the carpet covering the left rear tail light. There is a bolt with a nut on it that holds the tail light on. It is a very good solid ground.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 259 |
i used one of the bolts that holds the trunk on, On the left side under the wiring cover
ATX -Originally posted by bnoon: Get enough HP/TQ and some traction and you can race a ricer one handed while sipping a slirpy. Nothing wrong with that.
<font class="post">
16.251@85.42 mph
Posts: 4,639 |
the manuals for some amps (i think it was zapco i was checking on) specifically says to not use seat belt bolts for grounding. dont remember the reason though.
Hugo AIM:omegazodiac
Posts: 717 |
I just stuck a bolt into the floor or the trunk, of course after sanding it, works fine.
90' Bright Orange Mustang
65k - 13.306@105.1
Looking for another CSVT
~Blas~
