Originally posted by todras:
Impossible. Just solder in the new clips. Not that hard. You can't buy a complete harness that will just "hook up" to everythhing cleanly. Even if you get a later harness. The knock sensor will have to be tapped as well as other things.
the new engine is in, fired up and "ran" today
i only want the new wiring cause mines not in the best of shape.
btw, i didnt have to drill or tap any sensor holes they screwed right in!
i did have to grind the block a little for the starter to fit
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
