only thing you'll have to do is drill new holes. one at the top, 2 on the lower left/right side, and bottom hole. then just screw them in. try to screw them in over the vapor cover to use as a sorta gasket. if u dont want to cut the stock speaker ends, use wire taps to tap in about an inch after the stock speaker ends.
