Posts: 8,142 |
I just talked to John and he said that he cannot send a 15" sub to a canadian who claims to be the smartest person in the world. He thinks that being the devious cnauck you are, you will copy his design and make some kind of improvement, like adding blinker fluid to it, and steal all his profits.
Posts: 2,587 |
Drat! How did he know of such plans! DRAT! Now I'll have to find some other davice to test my blinker fluid!
1996 Contour "Mean Green" (99-02) 2002 Malibu Blue Focus ZX5 - something to hold the PB 15...
Posts: 8,142 |
You could try to market it as an alternative fuel source to the upper management at Lada.
Posts: 2,587 |
NO way Newman, I ain't listening to your crazy schemes anymore. Do you remember your El Contouro SVT idea? Well now I'm sitting here with a cut up Contour and Rolland and I are both broke. I knew we shouldn't have listened to you! Now we have to be jiggolos and the only chicks ugly guys like us can get are moose... this is all your fault
Posts: 2,246 |
I think I want to go the two 12 route. Are the Shiva's DVC? Cause basically my amp is 500x1 bridged, 175x2 at four ohms or 225x2 into two ohms. If they are DVC I would make it a 2 ohm load and if not, i would bridge the amp.
David Litsky AIM: DaveL225 My Car
Posts: 2,587 |
You can get the Lambda PL in a 12" size. They are better than the Shiva. I think they go for $179 a piece. Are you sure you con't want to go the two 15" route? only $40 more
Posts: 2,246 |
im trying to keep it around the price that I would sell my alchemy for
Posts: 4,585 |
Originally posted by David L: I think I want to go the two 12 route. Are the Shiva's DVC? Cause basically my amp is 500x1 bridged, 175x2 at four ohms or 225x2 into two ohms. If they are DVC I would make it a 2 ohm load and if not, i would bridge the amp. The Shiva is a dual 8ohm voice coil speaker. Wire the coils in parallel, then each speaker in parallel and you'll want to bridge your amp for 225w into the ohm effective load. You might want to check out the Stryke SAE 12" as they are 2 for $199 with about the same specs, but a little 300w power handling instead of 600w.
Posts: 8,142 |
You're amp would give the Shiva 500w. I would say to get one Shiva or one Dayton DVC 12 (Shiva Clone) because it may save you shipping.
Posts: 4,585 |
Oh, yeah, 500w x 1. Dave, saw this comparision with the Dayton and Shiva. Everyone else, this is some nickpicking details that you nor I would notice.
