N
NitDawg Offline OP
N
Well, it sure sounds like the shivas are the woofers of choice around here. I am going to be running a pyle millennium PL205. It is 250Wx4 at 4 ohms, 350x2 at 2 ohms, RMS bridged is 1000Wx1. I really have no clue what these mean as far as chosing the right woofer. Do I need 1 or 2. What are som good pre-fab boxes out there for the shivas...I really don't feel like builiding one.
On the same note, how do I go about hooking up both of my amps (the other one is for my door speakers). Do I run them both of the battery or run them in series??
Thanks,
nit
As far as hooking up both amps goes You need to buy a distribution block. Knukonceptz sells them pretty cheap.
I would buy 2 shiva's. It sounds like you have more then enough to power them.
Dnewma04 is the shiva man. I'm sure he will post on what size the box should be.
Matt--
1999 Contour SE
Go to www.subzoneusa.com and order something with at least 2 cubic feet (preferably 2.5) total. Meaning at least 1 cubic foot per sub. I'll get back with you on the amplifier.
Moderated by  dnewma04_dup1
