Page 1 of 6 1 2 3 4 5 6
#784377 10/29/03 11:34 PM
I don't know much about rpm curves and such, but can someone explain why the csvt can pull on certain cars. For example, Pontiac GTP's, Chevy Impalas, Dodge 5.0 R/T's, ect., really kill us off the jump, but I have noticed around 90mph thru 120mph we start to catch-up and eventually pass them. Its kind of shocking to them because you can almost notice they are grinning really hard and really hitting the gas and all of a sudden they see you in the rear view mirror closing fast. The contour is really a fun car to drive!! I ask because a few people have asked me, while shocked, what do I have under the hood and I just say a 2.5 V6. I really wish Ford would have continued to refine this vehicle.
Birthdate 1/6/2000 Mods: 35% Tint Bosal Exhaust K & N Air Intake, MAF Koni & Eibach Spec I/Spec Flywheel DMD http://www.villagephotos.com/pubbrowse.asp?selected=895138
#784378 10/29/03 11:38 PM
I would assume it is due to our lighter weight and flatter power curves. If they drop out of the power band it is harder for them to get back in that it is for ours. Aerodynamics also help out around those speeds.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
#784379 10/30/03 12:13 AM
Also keep in mind that running certain cars from a role, such as automatic GTP's, may or may not result in a downshift to the proper gear. I believe on the GTP's, a DHP (modified PCM) is required for performance skip-shifts (like 4 to 2 or 3 to 1). Like Johnny said, power curve has much to do with it, since at certain rpm's cars may not be at their power curve. My car is a dog until the secondaries open up at 3500rpm, for instance.
Tim
'01 GTP: 3.3" pulley, Headers, 3" Exhaust, Straight Pipe, Intense Air to Water Intercooler.Pictures Old Ride: 95 Mystique LS V6 ATX: Pictures
#784380 10/30/03 01:14 AM
Because out final drive gear is a 4.10 The power is more useful because the gears are closer together.
Mazda 6S, V6, Speed Yellow 5 Speed, Sport package Bose audio Painted 'stash and HIDs! w/Injen 1/4 14.750 @ 94.94 Former car: 99 Contour SE Sport Black MTX V6 SVT plastic... 1/4 - 15.012 @ 90.58
#784381 10/30/03 04:34 AM
Thanks for your responses guys! This stuff is very interesting to me and just good stuff to know.
#784382 10/30/03 04:40 AM
The Duratec final drive is 4.06
Yes our much flatter power curve helps, but so does the fact our coefficient of drag is very low for a production car. The SVT is even lower as the ground effects actually are there for more than just good looks!
Also comparing to the cars you listed they have a large torque advantage which gets them moving easier,but their portly weight and aerodynamics make them pigs once they are moving.
Perfect example of this is a Ford Lightning. Massive torque and great short numbers, but past 1/2 track it's a big fat dog comparably. (Think F4 - a brick with a big enough engine will fly! )
#784383 10/30/03 04:49 AM
Yet the Lightning still has a 4mph higher top speed than a CSVT,,, power .
#784384 10/30/03 04:59 AM
I have read the Lightning is aero limited to 143MPH
1998 SVT
#784385 10/30/03 05:02 AM
CSVTs are drag limited to 143. The lightning, atleast the newer ones are drag limited to 147.
#784386 10/30/03 05:05 AM
More proof.
Twice the HP, 3 times the TQ and roughly the same top speed.
B R I C K, fast
Moderated by  mbb41_dup1
