Hi everybody,
This post is probably related to the earlier one about a Contour that shakes like crazy while idling, but with a possible twist.
I'm new to the Contour -- I'm driving my husband's '95 Ford Contour (2L 4cyl 110k mi) while he's on deployment, and last Saturday I got an oil change, new oil filter, new air filter, had the coolant purged, the fuel system flushed, and the transmission fluid replaced. (My husband hadn't taken it in for quite a while.)
Since then, I've noticed that periodically when I'm stopped at a light in drive, the car will start shaking like crazy and the engine will sound like it is about to stall until I shift to park, and then it calms down. Sometimes when I start it up it will do the same thing while in park and I have to turn it off and start it up again (usually it's fine then). This doesn't happen everytime, just maybe one out of every four.
Also, the check engine light flashed on for about ten seconds during one of the idling episodes but then flashed off and it hasn't come on since.
Can these problems be related to any of the work I had done, or is it just a coincidence? It did recently get chilly here...
Meanwhile, my JiffyLube receipt says there's no warranty on the transmission service or coolant replacement service, and it notes that the transmission is leaking. (This sounds serious to me, but I was thinking it couldn't be that big a deal because there were no problems before the fluids were all changed out.)
I'm at a loss. I'm gonna get taken if I take it into the shop without knowing a bit of what's going on. Any guidance would be most appreciated as far as what might be the problem and how much it should cost.
Thank you in advance for any assistance you could offer this Contour newbie.
Meg
