Posts: 175 |
I sprayed WD-40 in the switch. The little tiny gap between the rocking part of the switch face and the body. You want to get the spray behind the rocking switch face plate. I did that to all my switches and worked them a little bit and it has worked ever since. All it really does is clean, I guess. I know some people think im retarded, but it Did work for me. My power door lock switch would not lock the door unless you used it from the passenger side. None of the windows worked right. Sometimes they would go downa nd not go up and vice versa. I did this and have not had anymore trouble.
Thanks
Blaze
1996 Sport LX Desert Violet Pearl(purple)
2.5 liter V-6
Finally Fixed
Posts: 2,975 |
I'm getting my lights on the driver's side going Dim. Sometimes when I press a button they go bright....Loose connection also?
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 115 |
Wich switch are you pushing?
Former, now returned CEG'er!
95SE MTX, (AKA "The Road Rat"). Stock except for:TH fix, B.A.T. big brake kit, tranny cocktail and lots of re-insulated wiring! May yet be a 3.0!
"Speed doesn't kill, stupidity does!"
Posts: 2,975 |
Originally posted by Stevedrivr: Which switch are you pushing?
Any window button on my main control one. But lately I can't get it to go bright at all. It's constantly dim right now. I'm going to take it off and look for loose connection.
-Tracer LTS spoiler
-GT Grille
Posts: 115 |
Any window button
Usually when you hit the window buttons the lights DIM a little. Yours are getting brighter when you hit the windows? A little weird. IMHO, start by checking the connections at the light switch on the dash as well as the connectors going to the headlight bulbs themselves. Make sure good connections and no corrosion. Also check your fuses for the headlights. Make sure no loose connections, i.e. the fuses are properly seated and a tight push in connection.
Posts: 4,294 |
got you all beat, just got my 99, the lights in the switches turn off and I lose power in just the window switches. sometimes just the lock thing (not the switch) sometimes both. the lock motor whinning a lot and I can't find to find a fix, about to pull that stuff out of my 95 and sell it with a broken one lol. no thats not nice.
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
