#779281 10/23/03 03:30 PM
O
Oeneus Offline OP
O
The mailman brought me my accel coil a few weeks ago, and I finally tried to put it in, but it won't plug in. The three pins on the coil don't line up with the wire harness, and it wouldn't quite plug in if they did line up. Did they change the harness at some point? How hard would it be to change the harness? I e-mailed zxtuner, and they said they only had one part# listed. Does anyone with a 95 have the accel coil? If so what part#?
thanks
Contour--It will make a master mechanic out of you! 95 LX MTX Bolt-ons 95 Neon SOHC ATX 77 Dodge Powerwagon-more displacement than my Neon, Contour, and wife's Saturn---combined!
#779282 10/23/03 04:27 PM
Sounds like you might have been sent the wrong part? I had one in my 99 SE, then when I wrecked it, we put it in Lee Cox's pre-98. I can't remember the year now, lemme look...
AHA! Lee has a 97, so no help there. AFAIK, there isn't a difference between the coil packs over the years.
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
#779283 10/23/03 04:38 PM
O
Oeneus Offline OP
O
IF it is any help, the part# is 140018. If you just eyeball it, it looks like it would fit, but it is just ever so slightly off
#779284 10/23/03 10:11 PM
If I recall, there is a rubber gasket inside the connector on the coil. I had to swap the gasket from the old coil onto the Accel in order for the plug to fit. This was on a 98 though.
Tom 98 LX (Zetec/ATX)
#779285 10/23/03 10:23 PM
no there isn't ford has been using the same coil pack for the 4 cylinders all the way back to 1991 when they switched to using coil packs on their cars
2003 Subaru WRX some mods Even if you don't have the answer, you certainly have to admire the problem. aka ZetecRacing
#779286 10/24/03 02:21 AM
O
Oeneus Offline OP
O
I'll look at it again this weekend, and try to get some pics. It IS close, but it just won't plug in. It bolts in to the car fine though...
#779287 10/24/03 02:29 AM
Do they use the same coil packs we use on the mustang 4.6L engines but just two of them?
#779288 10/24/03 03:06 AM
they use to they now use a coil on plug setup.
Moderated by  Loco4G63
