Posts: 165 |
The mailman brought me my accel coil a few weeks ago, and I finally tried to put it in, but it won't plug in. The three pins on the coil don't line up with the wire harness, and it wouldn't quite plug in if they did line up. Did they change the harness at some point? How hard would it be to change the harness? I e-mailed zxtuner, and they said they only had one part# listed. Does anyone with a 95 have the accel coil? If so what part#? thanks
Contour--It will make a master mechanic out of you!
95 LX MTX Bolt-ons
95 Neon SOHC ATX
77 Dodge Powerwagon-more displacement than my Neon, Contour, and wife's Saturn---combined!
Posts: 6,280 |
Sounds like you might have been sent the wrong part? I had one in my 99 SE, then when I wrecked it, we put it in Lee Cox's pre-98. I can't remember the year now, lemme look...
AHA! Lee has a 97, so no help there. AFAIK, there isn't a difference between the coil packs over the years.
Posts: 165 |
IF it is any help, the part# is 140018. If you just eyeball it, it looks like it would fit, but it is just ever so slightly off
95 LX MTX Bolt-ons
95 Neon SOHC ATX
Posts: 186 |
If I recall, there is a rubber gasket inside the connector on the coil. I had to swap the gasket from the old coil onto the Accel in order for the plug to fit. This was on a 98 though.
Tom
98 LX (Zetec/ATX)
Posts: 3,465 |
Originally posted by ChattavegasSE: AFAIK, there isn't a difference between the coil packs over the years.
no there isn't ford has been using the same coil pack for the 4 cylinders all the way back to 1991 when they switched to using coil packs on their cars
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 165 |
I'll look at it again this weekend, and try to get some pics. It IS close, but it just won't plug in. It bolts in to the car fine though...
95 LX MTX Bolt-ons
95 Neon SOHC ATX
Posts: 21,653 |
Do they use the same coil packs we use on the mustang 4.6L engines but just two of them?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
Originally posted by Kremithefrog: Do they use the same coil packs we use on the mustang 4.6L engines but just two of them?
they use to they now use a coil on plug setup.
aka ZetecRacing
