Posts: 181 |
Here's some info on my car first. 2000 Contour SE V6 ATX about 63,500 miles on it. Not a lot of mods to the car. Have an SVT exhaust with the resonator replaced by a glass pack. MAF adapter and a K&N RU-3530 air filter. Optimized throttle body. I used ford racing ignition wires (9mm).
Description of what happened. I was driving at about 35MPH (so I think the ATX was in 3rd), not accelerating. I heard a loud POP noise from low in the engine bay, towards the firewall. An air popping kind of noise. Immediately after that loud pop I could hear a repeated puffing noise. The frequency of puffs is linked to RPM. As I let off the gas and pulled over the puffing slowed down. I noticed that the steering wheel was shaking as well. After I popped the hood I could see the engine shaking more than was normal. I shut the car off, and let it sit for a few minutes while I looked under the car. I couldn't see anything spilling out. Or any debris from something coming off, under or behind the car. I started the car again, and the puffing was there right away. I was about 20 feet from the driveway to where I work, so I pulled in there. There is a slight hill up to the house (about a 40 degree slope). I didn't push down on the accelerator much at all. The car seemed to have just as much power as before. No struggling. I parked and checked the tail pipes. I could feel exhaust coming out both of the pipes. I'm not sure how hard the exhaust should have been coming out though.
My roommate, who is much better with cars than I, is coming to look at it later today. Any help or advice is greatly apprecited.
Make it idiotproof, and they'll make better idiots.
Posts: 8,445 |
sounds like a combination of an exhaust leak and a bad 02 sensor.
is it possible for an O2 sensor to blow out of the exhaust?
anyone...
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 181 |
I forgot to mention. No Check Engine Light Coming on either.
Posts: 228 |
Check this thread. May be your problem. Thread
Pablo Quintana
98 SE Sport Contour
Honduras, Central America
Posts: 2,166 |
If you put a rag in the exhaust pipes to constrict the flow, you can feel for an exhaust leak near where you think it may be.
You don't want to block them completely, or for a long period of time.
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 181 |
I don't need to block the pipes to feel the exhaust leaking. When I looked to see where the hoses from the EGR went to, I could feel (and smell) the exhaust fumes on my face when I got close to the EGR. I'm not too happy about that. I'm hoping the Ford dealership I'm getting it towed to in a few minutes doesn't try to worm out of the 8 year/80,000 mile emissions warranty. I'll give you guys an update when I get more info from them.
Thank you for the help. I might still need more, hopefully not.
Posts: 6,910 |
from the other post and what you are sying here it kinda sounds like another post i read. someone said the EGR pipe broke off of the exhaust manifold, soory but I don't remeber the name of the post or were that post was
- 95 Mystique LS - Zetec/5spd
Posts: 2,166 |
I'm sorry to hear about that!
Keep us posted on what the outcome is.
Where did you get your car towed to?
- Zack
2000 T-Red SVT
Posts: 1,228 |
Could of lost a sparkplug. Puffing could be air in and out of plug hole.
A few people have had plugs blow out.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 2,382 |
Check that EGR tube real carefully. See if either of the two rubber hoses that connect to it popped off. Your DPFE could have failed. You'll have to crane your head & neck to get a good look at the entire pipe (a flashlight helps) that could be part of the problem.... never hurts to check
good luck
"Fear is the little death."
Muadib.
