Page 5 of 9 1 2 3 4 5 6 7 8 9
Originally posted by beyondloadedSE:
the cams are the standard 2.5L cams.
how come you dont have SVT cams?
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
more overlap.
more overlap.
please explain...
i dont know alot about boost
since the svt has more aggressive cams, that means that the intake and exhaust valves are open longer simultaneously. its good on n/a engines, but when this happens on boosted engines, thats just wasted boost thats escaping.
i see, thanks for the explination!
Lookin good!! keep on trucking. I can't wait to seee the final product.
-Chris S.
99 Se,MTX,TS. Koni,Eibach,SVT Plastic,tunes,Opt Y-Pipe, Elky mesh, DMD, SVT BRAKING, Eo's, 95 Leather int.
Even though svt cams are not ideal, I still think there a better option than the SE. The cougars that dynoed didn't show the power gain that the SVT did. Even though they are running 9:1 compression stock, I dont't think the one point factored to much in the power difference (even though Keysers was dynoed w/ higher octane ).IMO. But still good luck, you will be making plenty of power anyways
'99 Silver svt For sale 19" Axis Neo wheels 3.0 parts, pre-98 trunk, Check classifieds bp.powell@comcast.net
W
W
Originally posted by e1flakedsvt:
Jim were you at street dreams in detroit two years ago?
nope...i think your thinking of bmxcontour who was there, who has the micah front bumper and has an electric red 95 contour atx.
yes, 3.0L heads have the bigger valves, no cam driven waterpump, and they are ported and polished. also, according to terry, using 2.5L heads can cause "hot spots" in the combustion chamber. the cams are the standard 2.5L cams.
shaun, thats fine if you want to race, on the drag strip of course. i just hope you can keep up.
Funny how the 2.5L heads don't cause hot spots when they are bolted on from the factory to the 2.5L block...which is essentially the same block with a different liner and the pistons which are essentially the same except a few millimeters wider.
W
W
No, the cougars/contour 2.5L duratecs are running 9.7:1 stock!!!!!!
This means only .3 difference.
The SVT motors work better from the breathing capability and some other factors.
i was talking about the 11.2:1 compression 2.5L heads causing hot spots.
