I WILL replace the stock set-up (HU and speakers) in the future but I have to make do with stock for now. I have a very annoying vibration in the driver's door when the speaker is playing anything that even resembles bass. The vibration doesn't seem to be coming from the speaker itself. It seems to originate forward of the speaker near the hinges. Any ideas?
Take the door panel off and see if the noise is still being made. This may help determine it the sound is coming from the panel or something internal in the door. Once the panel is off, you will be able to pinpoint any look connections, parts, etc. Once you find the problem, there are different ways of stopping the noise.
I still have warranty left so I am going to let the dealer play find the rattle. They ussually don't try very hard on this type of item though.
Sounds like a plan. Good luck!
APT Offline
Check the one screw on the front of the door panel.
Moderated by  dnewma04_dup1
