Posts: 3,732 |
i got 12 duratec camshafts !!!
4 3L 4 2.5 4 SVT
will i get triple the power if i put all 12 in the 3L?
Russell
Oval Port 3L Nearly Done
Posts: 199 |
my engine design has 6cyl in the space of 4.......i dont have a scanner stazzi but i can mail em......
Posts: 4,149 |
Originally posted by Zippy_Zetec: no DOHC=2 cams man.
And this guy gives car advice...
-- 1999 SVT #220 --
Posts: 1,231 |
Originally posted by sleeperv6: my engine design has 6cyl in the space of 4.......i dont have a scanner stazzi but i can mail em......
VR6?
-06 GTO Torrid Red/M6
-98 LS with BPU
-05 Honda Odyssey EX-L
mv .zig ..\for\great\.justice
Posts: 50 |
Well I have mentally designed an engine that gives 16 cylinders in the space if a V6
Posts: 1,660 |
Originally posted by IL Sean: Originally posted by Stazi the Aussie: You obviously have no idea... The extra cam would be redundant. You can have 3 valves running of each cam.... Also the more cams etc you introduce, the more valve train drag you induce on the motor. The cons far outweigh the pros.
Yes, I'm a Mech Eng myself.
Why not just amke the valves larger? More valves seems like going the roundabout way to get to the same point. But good job on thinking out side the box.
Because you run out of room in the head for larger valves and/or for better positioning of the flow. No, I'm not an engineer, I only play one on TV.
Scott
Troll! '99 BMW 328i
Posts: 7,117 |
Originally posted by cvkillacontour98: ... if you want to design a better engine design something stronger, with less weight, less moving parts, and more compact.
Can anybody say Rotary?
Posts: 7,117 |
Originally posted by Russell: i got 12 duratec camshafts !!!
4 3L 4 2.5 4 SVT
Yes, you will. Go for it.
Posts: 1,677 |
come back and eat your crow!
Posts: 1,049 |
a while back i had seen a article about stuff that was being worked on but i dont think ever came out. like electric valves and headgasketless engine and also a variable compression block that the head moves up and down to change compression. i think it was some stuff saab was working on. anyone seen that front wheel drive inline 6 on the suzuki i bet its pretty compact to fit in a front wheel drive car. i think its the suzuki verona it only has like 150 hp though(2.5 inline 6). one cool engien i saw in a magazine was a 1.6 twin turbo suzuki v8 it threw out 300 hp. i guess it never made it into production.
