Posts: 199 |
it has 3 rows of cylnders therefore 6 cams and the exhaust splits on two cylnders to one to join in the other 3....therefore makin it 4-1 exhaust on a 6 cylnder
Posts: 10,015 |
Sounds like an abomination.  I'd like to see your sketches if possible. Send them to anastazi.sarigiannis@aam.com
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,785 |
Originally posted by Stazi the Aussie: You obviously have no idea... The extra cam would be redundant. You can have 3 valves running of each cam.... Also the more cams etc you introduce, the more valve train drag you induce on the motor. The cons far outweigh the pros.
Yes, I'm a Mech Eng myself.
Hey I tried. I thought I had a good idea.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 2,676 |
Why not just amke the valves larger? More valves seems like going the roundabout way to get to the same point. But good job on thinking out side the box.
Posts: 1,049 |
from what i heard 4 valves flow just as good as a 5 valve engines. somebody was also telling me how the yamha r1 has a 5 valve engine and the susuki gsxr 1000 has a 4 valve and runs a bit better than the r1. if you want to design a better engine design something stronger, with less weight, less moving parts, and more compact.
Posts: 21,653 |
Originally posted by Stazi the Aussie: The Duratec V6 has 4, dopey!
I thought it was a DOHC engine. So it's a QOHC engine?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 6,910 |
Originally posted by Kremithefrog: Originally posted by Stazi the Aussie: The Duratec V6 has 4, dopey!
technically yes, for the Zetec it doesn't matter since it is a I-4, the Duratec is DOHC engine meaning each cyclinder has two cams above it
- 95 Mystique LS - Zetec/5spd
Posts: 2,007 |
Originally posted by brapple: Originally posted by Kremithefrog: Originally posted by Stazi the Aussie: The Duratec V6 has 4, dopey!
Or you could say that it has 2 camshafts per bank of cylinders. Overall the duratec has 4 cams, but it's not tagged as "QOHC," although i have seen some engines badged as "quad cam."
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 2,779 |
Posts: 1,521 |
SOHC = 1 cam per head (single "over head" cam)
DOHC = 2 cams per head (double "over head" cam)
Chris G.
~ 98 Mystique LS ATX
