Posts: 137 |
Hi, Anybody used the TopSider to change the ATX fluid. Idea is you plug it thru dip stick and let it suck old fluid out. Then you just add new fluid. No mess.
Posts: 1,459 |
Hmmmmmmmm. I probably wouldn't do it for a motor oil change, since I figure a drain from the bottom of the pan is probably more thorough than a vacuum removal. However, for an ATF change, as you suggested, it might make sense. The question in my mind is whether the tube could be inserted into the correct location in the tranny to remove all of the fluid.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 137 |
For the oil change it will work only on cars designed for such way (Mercedes, BMW) I heard about guy trying it on Honda with no luck. I wouldn't use it for the Contour motor oil change either - because Contour got the filter under the engine - so you'll be spilling oil any way.
So I guess I'll be the first one to try it on Contour's ATX
Posts: 1,459 |
Let us know how much fluid you can actually extract. IIRC the total amount should be somewhere around 10 quarts.
Posts: 137 |
Well, if you go thru drain plug you get only 4. So if i can get 4 - i'll call it a success.
Posts: 142 |
Let me know how it goes. It seems to me to be a good idea for the ATF!
1999 Cabernet Red Contour
SE Sport V6 24V ATX
Southern California
1995 White Ford Explorer XLT
Posts: 1,459 |
Originally posted by Kirill: Well, if you go thru drain plug you get only 4. So if i can get 4 - i'll call it a success.
Yeah, you're right, but as I see it, that's the problem with the drain. You only get less than half of the total amount out. It would be nice if removal from the top would actually get more than 4. Probably not, but I don't know enough about the internal reservoirs to know.
Posts: 1,603 |
Dropping the drain plug or sucking it out through the dipstick tube, will still yield the same results, without the mess. There is still 4 quarts of oil in the bottom of the CD4E no matter how you drain it. The other 6 quarts are in the cooler, the cooler lines, the pump, and the Torque Converter.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 137 |
Hi,
So - TopSider was able to pull only 2 qts of ATX fluid thru the dipstick.
Posts: 21,653 |
Did you drain out the bottom too and then see if it could get anymore? If all 4 qts would drain out the bottom, that's 6qts, which isn't too bad.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
