Page 2 of 3 1 2 3
Filling both roll restrictors may cause heavy NVH and will probobly not gain very much more torque at the wheels over the front filled mount and a new stock mount ( or you can use roof and flashing poly for the rear restrictor). This will keep it tight, but cut down on unnecessary NVH at the same time! If you think about it, this is probobly why Energy Suspensions still hasn't manufactured a rear mount insert! Usatisfactory NVH to torque transfer ratios.
a D*CK SLAP IN THE FACE IS ALL I GET FOR STICKING MY NECK OUT FOR A FORD... PLEASE DELETE MY ACCOUNT!
You are missing the ENTIRE POINT.
Less driveline lash equals better traction and less wheel hop.
This is NOT done to increase power output to the wheels. How could it? Once the driveline is wound up it's wound up. I suppose "technically" it would put more power down a hair sooner, but it will not make the driveline use less power.
This is just limiting the travel to maximize traction and minimize the driveline's effect on handling. (I.E. stop oscillations)
BTW I've tried all sorts of soft urethane and it never holds up for very long (3m window weld, industrial urethane, etc)
I can't wait to put in my roll resistors made from the 94A Urethane Casting Compound. (not just filled holes)
That is exactly what I am trying to explain. I guess the words didn't come out as acceptable as yours though.
Heres my pics of the front restrictor.
Just ran. ALot better grip, but alot more NVH as well. Has to be a sh&t load of NVH if you fill both mounts. Not sure if I really want to do that!
Hey... Your picture is worth 1000 words.
I guess you do get the point then...
The NVH is nothing. The added performance benefits far outweigh driving a luxo-barge... (I.E. no NVH)
The benefits on the highway are fugin' awesome over stock!!!! I think I just might go ahead and do the rear as well. This shiznick kicks a$$!!!
okay i did the search and nada, explain " roll resistors" and 94 a urethane. anything for less engine movement i am all for it. later
HORSEPOWERIC= ALL THE POWER IN THE WORLD STILL AIN'T ENOUGH 98 silver svt, modified y,ngk(indexed),pulley's,shifter,redline. future plans,custom borla exhaust, bilstein/h&r, rota slipstream 16x7 13 lb"s
9
Can some more info be found on this subject.. This sounds pretty cool.
I searched but only this thread came up..
Thanks
99 CSVT #91 - Silver Frost 2 3/4 Custom Exhaust Sho-Shop Y Pipe/Catless B & M Shifter VCN-2000
It's just take your motor and tranny mounts and filling them with polyuerathane to make them stiffer. Real simple to do and the benefits are great. Getting rid of as much wheel hop as possible is a must for any FWD car.
9
ok.. thats what i thought it was.. but for someone that drives around 350 miles per week work commute, won't this make the ride and the vibrations really bad????
Page 2 of 3 1 2 3
