#771941 10/14/03 08:25 PM
Kubiak Offline OP
I just took my car in to check a CEL it's had off and on for about a week.
They told me it was:
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
He also added that it occured in the low voltage position
He said he would replace one for 175 for parts and 60 for labor, and would do both for 410 (saving 2nd labor charge) if I did them both at once.
So, I have a few questions:
1. He said to replace both rear O2 sensors, should I?
2. What caused this, and how can I avoid it happening again?
3. Is his charge fair?
Thank you ahead of time for your replies
T-Red 1998.5 Contour SVT Mods: Foglight 'hack' Manual Antenna switch (Thanks for the idea Ryan Wood) 20% tint all around
#771942 10/14/03 10:02 PM
Gee, so would I.
Typical part cost is $65 - $70 (US).
Only the top rear sensor needs to be replaced. Always check the connector and wiring condition, a short to ground can cause this code.
#771943 10/14/03 11:57 PM
Only need to replace the Baank 1 precat sensor.
Bosch part #13115 about $50 at any AutoZone.
Check the archives for the how-to and save yourself a bundle.
AL
Red '98 SVT E0 3098/6535 DMD other stuff and a Bullitt fuel door
