Posts: 89 |
Ooooooooooh! You sure told me! Gimme a break, I'm not peddling the stuff! Man you guys are vicious. Excuse me for living! :-(
2000 Ford Contour SVT, black, bone stock.
"The way I drive, I don't need mods!" :-)
Posts: 187 |
there is no excuse for you....just dont do it again. LOL later man
HORSEPOWERIC= ALL THE POWER IN THE WORLD STILL AIN'T ENOUGH
98 silver svt, modified y,ngk(indexed),pulley's,shifter,redline. future plans,custom borla exhaust, bilstein/h&r, rota slipstream 16x7 13 lb"s
Posts: 21,653 |
You mean a piece of metal shoved into my intake won't gain me 20hp like they show on TV? I was sure my car was faster, darn.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 187 |
it will but only from 8500 to 10,000 rpm.......
Posts: 328 |
1999 CSVT-Black 15.8@89mph
Driver for hire. PM me.
Posts: 21,653 |
So as soon as I get a custom chip, new valves and cams,etc. then it'll be worth it. Sweeeet. Will it fit on my quad turbo/supercharger setup?
98.5 SVT
Posts: 187 |
well you will need to get the chrome plated tunnel ram setup with the dual 10mm tb's..........then you would be the man. LOL
Posts: 21,653 |
Actually I think I mite order the dual Weber carbs from burton, can you say hood scoop?
98.5 SVT
Posts: 8,143 |
that car they showed on tv anyway wasnt even stock if you look at it...it may have gained 20HP but 19 of that was from other mods done to the car.
If you look at it, I do see it somewhat increasing airflow but I don't think it'd make a big enough difference for you to even notice.
Posts: 9,602 |
Originally posted by ZetecNinja: If you look at it, I do see it somewhat increasing airflow but I don't think it'd make a big enough difference for you to even notice.
Really!
Please explain how an intake restriction increases airflow.
How does it magically make the engine pull in more air?
Air swirl before the TB has no effect on anything. For that matter air swirl in a dry manifold does nothing but slow the velocity down.
Matter of fact part of the reason a K&N works so well is it straightens the airflow out.
Also air swirl before the MAF (if it's mounted there?) causes erratic readings and drops performance and efficiency. Worst case scenario is it causes random lean spots
There is a reason why it doesn't work and is constantly made fun of.
2000 SVT #674
13.47 @ 102 - All Motor!
