Page 2 of 2 1 2
#770340 10/16/03 08:23 PM
When installing, do you need a new crank bolt?
98 E0 SVT with some stuff
#770341 10/16/03 08:28 PM
F
F
Yes the crankbolt is torque to yield and should not be reused. I did use my old crankbolt to help draw the new pulley on though, then took it off and put the new one in and torqued it down. You can get a new crankbolt from Ford for about 8 bucks I think.
Formerly known as Sneaku I MISS MY BABY!!! '00 Blk CSVT #1087/2150 built 12/23/99
#770342 10/16/03 10:43 PM
Originally posted by SpeedTeufel:
Originally posted by cawong11:
On my SVT, I really didn't notice much difference between the stock crank damper and the DMD. The obvious side effect of the DMD was a longer spool up time in the lower rpms, but that's about it. Above 4000rpm, it was the same as stock. One small observation I did hear on my SVT was the mechanical tone of the engine changed.
.....BTW, I'm running the stock crank damper.
Dude, now you tell me after I order one from you!
Here's the thing, as I mentioned before, I didn't like the increase in spool up time so I went back to the stock damper. No negative side effects of the DMD, though, so it's not a wrong choice.
#770343 10/20/03 02:47 PM
Was just kidding man, I would have went with the DMD anyway because I put approx. 130 miles a day on my car. If I didn't drive it that much I would'nt have changed it.
BTY I got it in the mail this weekend I will be installing it, wish me luck.
98.5 Black SVT 65 Red Mustang coupe 289 hi-po
#770344 10/20/03 05:40 PM
Originally posted by ScottK:
Any insider info or unpublished engine failures lead to this change in thinking? Any new tidbits from procyon or Terry???
Nope. I still stand by my opinion that main intent of the DMD is to address NVH issues. I know that it is much more expensive than the regular damper. That's probably why it's only used on higher priced or higher class vehicles where the customer expects a smoother, quieter engine. As such, it's not standard equip. on the Taurus, Escape, or Cougar.
Page 2 of 2 1 2
