#770330 10/12/03 10:18 PM
9
91g60 Offline OP
9
who can install the under drive pulley's for me i will pay!!!!!
#770331 10/12/03 11:52 PM
O
O
a mechanic or performance shop!!!!!!!!!!!
~nick 2001 Cougar V6 MTX 3L Cougar.
#770332 10/13/03 03:49 AM
9
91g60 Offline OP
9
do you gain hp also i have heard it's extends the life of the components is that true.
#770333 10/13/03 06:08 PM
No change in peformance vs stock damper.
Drastic change in engine feel and vibration control.
"Technically" the reduction in vibration will have a positive effect on longevity and reliability.
However the same can be argued that it is only an NVH upgrade.
Personally I've fallen off the band wagon believing a DMD will help with crank whip. Engine component speed and subsequent forces at high rpm are just far too strong for it to make any difference.
Using logical thinking it still "should" help with longevity of internal parts by reducing vibration, but only if you keep the rpm level down. Also with that said there are many folks with very high mileage running the OEM damper as well.
Also I know of at least 1 DMD failing on a high powered Duratec engine. I would say it has a HP/TQ limit you should not exceed!
#770334 10/13/03 06:33 PM
F
F
Say it ain't so! You've been like the leader of the "Get a DMD" crew for ages now! Come to the darkside Luke!
Formerly known as Sneaku I MISS MY BABY!!! '00 Blk CSVT #1087/2150 built 12/23/99
#770335 10/13/03 06:59 PM
On my SVT, I really didn't notice much difference between the stock crank damper and the DMD. The obvious side effect of the DMD was a longer spool up time in the lower rpms, but that's about it. Above 4000rpm, it was the same as stock. One small observation I did hear on my SVT was the mechanical tone of the engine changed.
.....BTW, I'm running the stock crank damper.
#770336 10/14/03 01:13 AM
I will. How much money you got?
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#770337 10/14/03 02:35 AM
Dude, now you tell me after I order one from you!
98.5 Black SVT 65 Red Mustang coupe 289 hi-po
#770338 10/14/03 02:53 AM
Any insider info or unpublished engine failures lead to this change in thinking? Any new tidbits from procyon or Terry???
97 Contour SE MTX K&N 3530, UR UDP, 19# Injectors, mystery mod, FMS wires, Fordchip.com chip, SVT: TB, Flywheel, clutch, exhaust 04 Grand Caravan SXT
#770339 10/16/03 05:30 AM
6
ttt
Former - 98 CSVT E0 T-Red 4/4/97 #173 of 6535 Dear Santa
