Originally posted by KnuKonceptz:
Or, have a local alternator shop equip your alternator with an external voltage regulator. I did this and could have my car at idle charging at 18V if I wanted too, only took it up to 15.4V though. That wont change the amperage but you will have more voltage to play with
What would be the cost of this mod? And how would this eliminate the dimming problem when the 'amperage' that the alt is putting out isn't increased? I was quoted a price of $400+ for the 200amp H.O. alt. But the thing that makes this less feasible is the fact that the alt. only increases its output above 2-3k on the tach. (which doesn't help if you are sitting at a stoplight idling)
I agree with Dave...that doens't happen very often. Get the H.O. Alternator first. This Item will single handly fix any and all problems with dimming. Your car was setup from the factory with the amount of amps need to run the car, 75 if I remember right, and a few extra amps available for accessories, 85 total, but NOT for aftermarket stereo's...you have maybe 10 extra amps. Then get the Alumapro...BTW they make a 5 farad CAP now...cheaper!! you don't need the 15 for your car, you really don't even need the 5...GET THE ALT!! It'll be worth your time and notice a big difference.
The 5 farad cap would be sufficent. I am of the premise that more than enough is better than to little. But I don't believe in 'OVERKILL' which I think the 15 farad would be. But capacitors are one of the accessories of car audio that falls between the cracks. When you goto all of these car audio websites you see Amps, Speakers, and HU's. A link to where I could purchase the 5 farad would be greatly appreciated. I just want my 'super-system' to be fed enough voltage with little if any drops so the 'SQ' of my system remains constant. I have seen what that 'dip' in voltage causes in a system. I have a very 'tuned' ear accoustically. I have heard many systems that sounded like garbage because of improper wiring/voltage/ and component level settings as well. So I am not going to 'skimp' on anything seeing as I have spent damn near $3000 so far on my system.
Thanks for all the replies, I appreciate all the insight you guys are providing
