Posts: 5 |
The top one is easy but the lower is very hard to reach and no way to see it  so I need know what size is it.
Posts: 2,779 |
You mean IAC? If so, they should be the same size. I took off some of the stuff in the way to get to the 2nd nut. Makes it easier.
Posts: 5 |
Yet,it's IAC,mine is 95se,are they the same size with SVT?I didn't feel it the same when using my finger to touch it.
Posts: 2,408 |
You are talking about this right? What would you take off that was in the way?
Posts: 2,779 |
Yup, that's it. I took off the cylinder shaped thing at the top of the picture that has 2 bolts going into the UIM, that way I could get at the bottom nut from that side.
Posts: 2,408 |
I have never had to remove the EVR to get the IAC off. The bolts are pointed at the firewall.
Posts: 2,779 |
Yes, they are. But what I am saying is that I took it off so I could position the wrench from that spot because I could not reach it from anywhere else.
Posts: 1,145 |
the bolt is a 10mm IIRC y r u taking it off to begin with?? if your doing something with the manifold and removing it too dont worry about removing it
98.5 Black SE ATX
Posts: 191 |
This is interesting because I was wondering the same thing, but more for replacing the bolts.
Does anyone know the SPEC?
The IAC comes with two different styles...mainly because it puts a hose clip on one end of the bolt (top bolt close to hood)
I want to replace this one because the head is starting to strip...
Anyone have the spec, dia. etc?
'95 Contour SE - MTX
All stock...except for my Canadian Tire cup holder
270,000 kms (April 2004)
 GO BABY GO!
Posts: 5 |
Ok,you guys are right two bolts have the same size but in differen shape and EVR had to be removed to give me some room.After the cleaning the car runs pretty smooth now also the stalling problem is gone.  BTW IAC bolts are 8mm,7mm for EVR.
