I'm assuming you already have the JVC HU, so here goes:
-Bypass the factory amp and run front and rear off the HU. The factory amp is turd. That should help a bit.
-Just curious, but why did you put the smaller speakers in the back doors? If you are planning a sub/amp, then you will want the bigger speakers in the front since they will blend the front with the back much better.
-A sub/amp is one of the biggest inprovements you can make to a car's stereo system. Even a 10" driven by a 100W - 200W amplifier will add alot to your car's system. For this, you are looking at anywhere from $300 - $1000 depending on brand, materials, installation, and how high grade your parts are.
-And make sure you buy Bose stuff, they make the best clock/radios on the planet!
