Posts: 2,211 |
I've been waiting for pics from you for a long time. I can't wait to see what the finished product will produce. You seem to be one of the very few who have completely knoweledged themselves with almost everything and THEN did the project. I believe that you will turn out one of the most powerfull Tours in the world and I bet it will outlast them all too. Awesome work
Posts: 1,756 |
The "workshop" needs to be relocated to the first garage from the first set of pics for more room  . Good luck and hope that everything goes smoothly.
Posts: 1,943 |
Originally posted by beyondloadedSE: Current list of modifications 1999 3.0L 24V Duratec shortblock Forged Aluminum Ross Racing 8.5:1 pistons Forged Pauter connecting rods 1mm overbore and balanced crank Clevite 77 and Federal Mogul bearings Street Flight Turbo Kit -T3/T4 ball bearing turbo -Spearco upgraded Water/Air intercooler -Stainless steel turbo manifolds and collector pipe -42lb injectors -Water resevior and pump Walbro 255lph fuel pump Ported and polished 3.0L heads Mondeo ST220 3.0L valve springs 2000 SVT lower intake manifold BAT Electric Waterpump and controller 3.0L Valve covers 2.25" Magnaflow exhaust Dual mode dampener Bulldog Box Transmission -Quaife LSD -Zetec 3.82 final drive ratio -Post 2000 shifter forks -All new bearings Fidanza 11.5lb Flywheel SPEC Stage III clutch Driveshaft.com Stage 2 axle shafts Apexi AVC-R boost controller 2002 Mustang 80mm MAF Lotek gauge pod Autometer mechanical boost gauge Autometer electrical oil pressure gauge Autometer electrical pyrometer gauge Din slot LCD screen with Brake temp, Water temp, oil temp/pressure, boost pressure, air/fuel, throttle position, and intercooler efficiency measurements.
Special Thanks to: Buckshot Motorsports, B&N Motorsports, Nikolas @ Duratec Performance, Keith @ Street Flight, Terry Haines @ HMS, Jesse King, Brian Phillips, Warmonger, Bill Jenkins, and the rest of the CEG community with their support.
that is the sweetest mod list i have evar read! im sure roger cant wait to take a trip to IN to see the inveiling of your ride man. now get to work!
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 259 |
ATX -Originally posted by bnoon: Get enough HP/TQ and some traction and you can race a ricer one handed while sipping a slirpy. Nothing wrong with that.
<font class="post">
16.251@85.42 mph
Posts: 8,143 |
thats a lotta crap u gotta install...gonna be another year and a half before we see it on the street.
Posts: 9,196 |
Congrats on getting the motor back Jim  Not that its too important, but did they hot tank the block first, it doesn't look that clean  Now the heads look brand new, are they  The exhaust system looks really cool, I can hear it from here! It looks like our trip down there will have to wait till the spring unless you find a way to get everything installed, tuned, adjusted, re-adjusted, test run and then re-checked before the weather starts to suck. BTW, are you still thinking about changing the color of your car? If so you might wanna have the engine bay painted that color while the motor/trans is out  Once again, congrats and 350 hp is coming your way
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 287 |
Congrats and now to install it
04 Blue WRX
-Rota Subzero's 17in gold,Cobb Tunning Stage 2 93 octane, tein springs, 3in -turboback with magnaflow muffler + 1 resonator  2 1/4 up-pipe Former owner of Conniethecontour 99 CSVT...My first love
Posts: 4,713 |
Good work, Jim. I think you'll be cruisin' a powerful and reliable machine within the next few months. Make sure it's broken in and tuned before you go testing out it's capabilites, ok?  BTW, why 42lb. injectors? Aren't they overkill?
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 3,732 |
Originally posted by Derk2000: BTW, why 42lb. injectors? Aren't they overkill?
i think he plans on cranking up the boost to 15+ psi at the track.
he can safely do it with his forged rods and pistons
Russell
Oval Port 3L Nearly Done
