Page 1 of 3 1 2 3
#765236 10/06/03 05:05 PM
Blevans Offline OP
Bought this 98 GL ATX at 85K and love it. Uses no oil, runs great! (90K now) I can not find out what oil the previous owner used.
I have been using dino oil. Should I or should I not switch to a synthetic. What would the pros and cons be?
I have been told if you switch to Synthetic you should NEVER go back to dino oil,(RUINS SEALS). How true is this??
Col. Bill Evans CAF (ret) 98 Contour GL Zetec ATX (totally stock) Color-Willow Mist 104,XXX Miles
#765237 10/06/03 05:10 PM
So many posts on this. 90k is many miles to many switch.
#765238 10/06/03 05:10 PM
Should.....
Pros and Cons...use the search feature...many many articles here.
False...have switched (in the past) back and forth when $$$ was tight...now have 111,000 miles...no leakie
Mobil-1 5-30
Motorcraft 810s filter
Don't worry...be happy...
EDIT: Damn you todras...for beating me...get a job!!!
#765239 10/07/03 02:11 AM
He probably has a zetec, do NOT use a motorcraft 810 filter unless you have a duratec. I switched to mobil1 at ~83k miles with no problems.
#765240 10/07/03 02:49 AM
Don't use an 810s filter for EITHER engine.
Stock Duratec filter is an FL-820S.
The filter I recommend is a K&N HP-2010. If it were a Duratec...
#765241 10/07/03 02:51 AM
I would recommend some zetec filters, but I believe the 98+ may be different from pre98s.
#765242 10/07/03 04:37 AM
The FL 810 oil filter fits Festiva's.
#765243 10/07/03 12:46 PM
(Steve Martin)
O-k..so sueeeeeeeeeeeeeeeeeeee me!!!!!!! I was going off the top of my head...and knew that anyone who cares about their car would double check at the store anyways...
Taken my bat and ball and going home....
#765244 10/07/03 01:15 PM
its only bad for old cars with high mileage, to switch to synthetic. i used to believe this as well. i was straightned out of that thaught quite fast, you should have no problem. my brother has a 91 plymouth acclaim, 76 Nova, and 85 'maro......uses Mobil 1 all the time. no damage, or leaks yet.
#765245 10/07/03 01:57 PM
I have a '97 Zetec, switched to synth at cca. 120k now has
155k, no problems, no oil consumption.
Before that I was strict on changing oil on every 3k miles,
when gone synthetic I changed first after 2k then 3k, after
that 5k.
The last 2 times I used synth blend because I think it's good
enough - when I drained it after 5k it was still in very good
condition.
Tiv
Page 1 of 3 1 2 3
