CEG road warrior
CEG road warrior
Posts: 17,248 |
Every tire that came on the Contour (except SVT) had H rated tires which is 130MPH. Most stock Contours can't go that fast.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 4,220 |
well, its easy to mis-read a speedo when your doing 120!!! that can be scary [censored]. especially if your running stock tires... all it takes is one wrong move, one twitch of the steering wheel at those speeds. i love doing it. thats all im gonna say for fear of getting the thread locked...
Heh... All I'll say is don't drive with me on the way to work. 35W is a nice straight road with minimal police.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 53 |
Originally posted by DemonSVT: Originally posted by Stebo: I've had my CSVT doing 140mph (according to speedo) and I was pretty much tached out. Just thought I'd share that with you guys.
Then your tach is broken or you put 22" tires on your car...
Why would you say that? It makes sense. You ever tried it? I hit 140 in 5th gear and I was doing at least 6000 RPMS - stock rims and tires. Can anyone else support me here?
1998.5 CSVT 34,000 miles
2005 Volvo XC90 V8
1971 Duster 360, 3.55 POSI
Posts: 4,149 |
I'm no math wiz, but if you take the diameter of a stock tire, the final drive ratio, and the gear ratio I'm pretty sure it won't add up to 140mph @6000
-- 1999 SVT #220 --
Posts: 1,360 |
can u say Radar/laser jammer/detector?! mine was 250 dollars at best buy. i dont get caught anymore! afte rmy last ticket ($450...47 in a 20) i will never be caught again... ok i might but at least i wont be doing 27 over...more like 10... i like hwy 377...but watch out around watauga...those public saftey officers will get ya!
Posts: 53 |
Originally posted by bigMoneyRacing: I'm no math wiz, but if you take the diameter of a stock tire, the final drive ratio, and the gear ratio I'm pretty sure it won't add up to 140mph @6000
I'm not trying to B.S. anybody, but I could have swore when I hit 140, I was pretty much tached out. It was a couple years and quite a few drinks ago, so maybe my memory has faded a little, but from what I remember it was slightly over 6000. I'll try it again here soon and post results. Please don't think I'm trying to b.s. you guys because that's what I honetly believe to be accurate.
2005 Volvo XC90 V8
Posts: 4,639 |
Originally posted by Stebo: Originally posted by bigMoneyRacing: I'm no math wiz, but if you take the diameter of a stock tire, the final drive ratio, and the gear ratio I'm pretty sure it won't add up to 140mph @6000
why is that wrong. if top speed is 143 (drag limited established), then it should be hit in 5th gear at max rpms. the svt goes above 6000rpms.
Hugo AIM:omegazodiac
Posts: 4,639 |
Originally posted by LoCoZ: On the dyno my car was up to 135mph in 3rd gear (O/D off)at 6800 rpms.
WHAT? no freakin' way. then you must be running some juice. svts hit about 120 in 4th at max rpm on a dyno. mine did along w/ every svt dynoed at the last dyno meet i was at. your 120hp atx will not do it. if it was a joke, sorry, i didnt get it.
Posts: 4,639 |
demon, is that true about governor of 250 for svt? first time ever hearing that
Posts: 4,693 |
I don't know what the RPM would be at 143 MPH since I have not tried to go that fast, but there is no reason to believe that it MUST be at max RPM.
I'm not sure, but it seems like I'm tacking 3500 RPM at 80 MPH. If that is correct, my slide rule shows that 143 MPH would be pretty close to 6300 RPM. This is about what I would expect, that you would run out of horsepower before you hit red line in top gear.
Part of the art of tuning for drag racing is to find the gear that will put you very close to red line at the end of the 1/4 mile. This is a little bit of an over simplification since there are many other factors involved.
With this thought in mind, it is concevable that you could get a little more top speed with a slightly lower gear set, if you could find or make a gear set that would get you into this "sweet spot". I suspect that the performance 4.50 gear set that is available somewhere is too low unless you were able to raise the red line.
Jim Johnson
98 SVT
03 Escape Limited
