#76189 05/17/01 06:40 PM
Macmadd Offline OP
I bought an alternator filter to filter out the alternator noise. Can anyone tell me where the alternator is located and which/what color wire I need to put the filter on? Any help will be greatly appreciated.
Don LaReaux
2000 Contour SE
Nakamichi 40z HU
Kicker i570 (front)
Stock (rear)
2 10" JL subs
Memphis 16-ST500D (500rms)amp
Rockford 160.2 pushin the front Kickers
#76190 05/17/01 07:00 PM
Is this a typical noise filter, or an actual "alternator filter"?
If it's a regular noise filter (which it probably is), you just wire it in-line on your amp's power cable. It should also have a ground, which you should appropriately ground.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#76191 05/17/01 08:30 PM
Macmadd Offline OP
This is an alternator filter. It has two wires. I bought it from crutchfield.
Don LaReaux
2000 Contour SE
Nakamichi 40z HU
Kicker i570 (front)
Stock (rear)
2 10" JL subs
#76192 05/17/01 09:25 PM
Did you buy the "PAC ANS-80 In-line Alternator Noise Filter"?
The alternator is a small generator run off the accessory belt in the engine compartment. Splice it into the power wire coming off of the alternator.
I can't tell whether or not it needs to be grounded. Just make sure to follow the supplied instructions on the wiring.
1999 SVT #900/2760
Born on 1-20-99
#76193 05/18/01 03:26 AM
Macmadd Offline OP
Where exactly is the alternator located and what color would the power wire be?
Don LaReaux
2000 Contour SE
Nakamichi 40z HU
Kicker i570 (front)
Stock (rear)
2 10" JL subs
#76194 05/18/01 03:27 AM
Macmadd Offline OP
Oh yeah....it is the PAC ANS-80 In-line Alternator Noise Filter from crutchfield.
Don LaReaux
2000 Contour SE
Nakamichi 40z HU
Kicker i570 (front)
Stock (rear)
2 10" JL subs
#76195 05/18/01 02:06 PM
It's on the left side of the engine compartment and a PITA to get to. Your best bet is to get a Chilton's manual instead of me trying to explain how to hook it up. You don't want to put it on your starter or something and let a bunch of electrical gremlins loose on your car.
They've got pictures and specific diagrams, a big help.
1999 SVT #900/2760
Born on 1-20-99
#76196 05/18/01 10:10 PM
Macmadd Offline OP
Yeah I hear ya. Ill get one of those manuals before I try. I appreciate the responses, no doubt!! If I feel its gonna be to hard I wont do it although I dont think it'll be that hard. Thnx again.
Don LaReaux
2000 Contour SE
Nakamichi 40z HU
Kicker i570 (front)
Stock (rear)
2 10" JL subs
#76197 05/20/01 05:16 AM
I believe if its a pac filter you hook it up to your RCA jacks running from you pre outs and then connect the cables to it. The alternator has nothing to do with the hookup
Brian
2000 SVT Green
KKM True Rev
Pioneer 6200 Head Unit
Rockford 800a2/600a4 amps
Infinity kappa's/Polk 12" dx128 subs
Short throw shifter/Voodoo Knob
ADR Revolution Rims
Toyo T1S 215/45/17
Bassani Cat Back
Next Mod: SHO Y PIPE/Diablo Chip
Moderated by  dnewma04_dup1
