W
W
Installed front speakerslast night but wasnt sure which wire is positive. Brown or white?
Mike
2000 SVT Contour
I am pretty sure that the brown wire is positve. It's been awhile since i installed mine. It shouldn't hurt the speaker and you can always switch it back.
Matt--
1999 Contour SE
I am almost positive white is positive and brown is negative.
-Colter
My Car
W
W
Well, it is now a tie. Any others that know which way it goes? I guess it wont matter when I hook my amp in but it is nice to do things right.
Mike
2000 SVT Contour
Posted in another topic......
If you MUST cut/splice the wires, on the speaker wiring harness the brown wires are generally negative and the white wires are generally positive.
The adapter is a much easier way, but if you splice and dice, MAKE SURE YOU SOLDER THE CONNECTIONS after you get everything right and then cover each wire wires with good grade electrical tape, shrink tubing or both.
Good Luck.
REV VT
rfolden@excite.com
95 MM V6 MTX Debadged Deep Purple
Daily Driver 80 Mile Commute
-Colter
My Car
No help from me... My Alpines were in the car when I bought it. Just a reason to post! (I'm bored!)
-Ken V.
psycho_bass@hotmail.com
My Car
1
1
Brown is definetly the negative!
Told you so
:p
laugh
-Colter
My Car
Moderated by  dnewma04_dup1
