Page 4 of 4 1 2 3 4
I'll keep my McIntosh, which also compliments my HU nicely. smile
Originally posted by dnewma04:
I think I'm on KnuKonceptz side of this argument. The effeciency of the amp would play a big part in the amperage draw that a amplifier requires.
Apt, I understand where you are coming from, but I think you are looking at the wrong end of the amp to get the results you need. What you are measuring is the amperage at the output of the amplifier, but you should be measuring how much juice it takes to create that output. Your math is correct, but you are just looking at it the wrong way.
Damn, that was tough to stick up for Knu!! wink
I had to see it again to Believe it.....LOL
Pioneer's ODR amps are Class A also, but I have seen only 2 cars with them in it, both several thousands of dollars install, each amp alone is grand retail and has to be used with there ODR HU and EQ's
Page 4 of 4 1 2 3 4
Moderated by  dnewma04_dup1
