W
W
Where do I run the power cable through the firewall? Do I need to drill a hole?
Mike
2000 SVT Contour
Mike
2000 SVT Contour
well i dont know about your car but on my contour on the right side behind the brake fluid and all that down under there there is a small little tear shaped plug. Its about 1 inch by 2 inches, and if you pull it off and kind of poke through the material it comes out right under the dash behind the brake pedal and near the fuse panel. Then from there you can just run it under the side panel to the trunk or wherever. This is just what i did on my car i am not sure if it would be the same for yours.
mzatt
-95 Contour GL
-00 Integra LS
Mike
2000 SVT Contour
or you could take off your windshield wipers and the black cover, once you do that, you will see a black rectangle on the right, poke through that and presto theres your hole
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
If you have cruise control, kind of behind and underneath it there is access to a grommett. You have to unbolt the control unit to get to it. I have 4awg running through it.
Mike
Silver '99 SE V6 MTX,
Eibach, Koni, Res removed, Dynamax
B&M, Boston Acoustics, Fosgate, JL, ST200 wheels
I also used the hole behind the CC unit.
Mark
On my SVT there is a gromet on the drivers side, its round and sorta near the top of the firewall right in front of the steering wheel, if you poke through that you gotta go through another part of the firewall then you have to poke through some insulation into the floor, youll come out above the pedals, stick a thick hanger through there then look under for your hanger. I managed to fish 2 gauge wire through there perfectly.
00 Black SVT #1545
Ground Control. Koni. 18" Konig Tantrum. More.
Moderated by  dnewma04_dup1
