Posts: 1 |
Hello,
I've been working on my stepmom's '98 Contour SE. It has the Zetec 2.0 liter in it. I'm trying to change the VCT Solenoid because it has gone bad. So I need to take the timing gear off the exhaust cam. I took the end plug out and there is a torx looking bolt, is that a bolt or is it the end of the cam. Does it all unbolt in one unit or is it springs and stuff inside the hub that is going to fly apart. I'm in dire need of help. Thanx for any help.
Posts: 21,653 |
That is a bolt, I don't have vct though so I can't really answer those other questions. I would personally remove the vct and live with a CEL.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
The bolt inside the cover just comes off. Then you can pull off the cam gear.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 89 |
Originally posted by Kremithefrog: That is a bolt, I don't have vct though so I can't really answer those other questions. I would personally remove the vct and live with a CEL.
"Removing" VCT will create a worse idle than the Zetec already has & since it takes the place of an EGR setup (which keeps combustion temps within manageable levels), you might be promoting earlier engine self destruction...my $.02.....
Is the smoke alarm in your house also known as the dinner bell?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
Posts: 2,291 |
The first thing you took off was just a plug. The bolt underneath is what holds it all together. It should be some funky-ass looking star pattern (like a reverse torx), but a normal socket will work - 5/8", I believe.
Of course you'll need to remove the intake timing gear as well, since there are two small bolts that hold the VCT solenoid to the head. You can't get to them w/out removing both timing gears.
The exhaust cam will also need to come out. The solenoid is a one-piece unit that fits over the cam. It can only be removed by slipping it off the end of a removed cam.
![](http://home.flash.net/~mrfax/D/teardown/no_vct.JPG)
Obviously the big round section is what fits around the cam.
At the top of the 'canister' is the plug that sits at the top of the valve cover with the electrical connection.
See the three holes under the canister? The two outside holes are the two I mentioned that you remove from outside the head. The center is an oil-feed line. If you're removing VCT completely and not planning to put it back, I've heard it recommended you plug the corresponding hole in the head. The oil pressure may be too high exiting the line on the head and 'could' cause problems (this is all heresay, so you should investigate on your own as well).
I'm experimenting w/ removing VCT completely, but as mentioned already I haven't came up w/ a work-around for getting EGR functionality (unless the head is completely swapped, of course).
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ABNeg: Originally posted by Kremithefrog: That is a bolt, I don't have vct though so I can't really answer those other questions. I would personally remove the vct and live with a CEL.
My idle is fine. VCT is not working (got adjustable cam gears).
Hector
257HP/259TQ
160HP/141TQ
Posts: 119 |
Actually if im not mistaken, VCT was designed specificially to reduce emissions and have this beast burn cleaner. Now if you look at the 00-present focus they got the same engine w/o VCT. look at the VCT on the SVT focus, thats on the intake cam to boost performance... i think its safe to say taking VCT out wont hurt your car any
Turbo'd Cougar 2.0L w/ 75 shot ... its got some stuff in it ...
NOT that fast NOT that furious :P
Posts: 2,974 |
Hector how is your car working right wiht your VCT acting up? mY VCT is faulty and even tho my car is driving fine it's over advancing the timing and making it run lean(at least thats what the computer says everytime i scan the codes). Any other suggestions on what the problem could be? Sorry to hijack the thread.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 21,653 |
Hector's VCT isn't acting up, because hector doesn't really have VCT anymore.
98.5 SVT
CEG road warrior
CEG road warrior
Posts: 17,248 |
Well my car is not running lean...I just have a nice CEL.
Hector
257HP/259TQ
160HP/141TQ
