Cleaned UIM using "shop| method. Used Berryman's and it worked well! When I was thinking what hosses/clamps to use I remembered the disposable IV kits I had laying around the house. It worked like a charm! Just plug the IV bottle side of the IV kit in to the whatever you are using and hook the other side in to the vacuum out on the UIM. The ends of the IV have these nice rubber endings that are perfect seal against the vacuum outake on the UIM. The kit has flow regulator so one can fine tune the ammount of juice going in to the UIM. Just perfect. The only minor problem is that the hoses itself are relatively weak against the vacuum so it takes some time to empty the can (about half an hour for both sides) but since one needs to warm up the engine for oil change anyway it's not a problem. And gettng the vacuum hoses off was easy. Once again the value of this list proves itself. Thank you all for your contribution in learning this way of UIM clean up. I know that purist may disagree about this not being the right way, and they are probably right but it helps when one does not have the time for full job,
airman1 Black '95 Mondeo V6Si
