Page 2 of 2 1 2
I am not getting a CEL...but what is funny is mine did it even before I bought it...when I was checking it out..thought cause someone left the air on....well it still did it...was in the stealership for a cel and they fixed the vac leak...stopped for awhile..then it began doing it again...was in the stealership for something else and they didnt say there was a vac leak...hmmmmmmmm..wierd....
Alicia 96 Contour LX 2.5L V6 Duratec Stock of course! BAD ASS GIRLS DRIVE BAD ASS CARS!!! http://www.cardomain.com/id/sweet_ride01
Originally posted by contour96:
in the stealership
Stealership, BWAHAHAHAHAHAHAHA, good one, never heard that before, my thanks, you made my day !!
Ken, 99 Silver Frost SE Zetec Atx, polished alloys, Kumho's, Pioneer hi power CD/AM/FM. Factory spoiler (added) Audi side lites, Borla stainless steel muff. Stolen, recovered in pieces. Looking for another Tour, preferably V6, 5 speed.
Welcome!!!!! I got that from one of my fellow michigander ceg'ers....I thought it was cute and funny....but isnt it the truth????
Is the MAF sensor the one that is screwed on like a spark plug? what is the name of the sensor that is held inside the square plastic box just past the air filter and just before the plastic tubular piece that says MAF? I was told it is the one inside this square plastic box that I should clean? My car was hessitating for first 30 sec of cold start.
That would be the IAT. No this would not cause hesitation.
The MAF can cause this. So can vacuum leaks and fuel pressure problems.
FWIW- The square plastic box is the 'air box' with the air filter and the IAT, aka Intake Air Temperature sensor. I would also check for loose or cracked hoses leading into the the intake, but a bad IAC (Idle Air Control) valve is fairly common. At $80 for a replacement IAC, it's worth a close look at ALL the other hoses to make sure their OK before buying a new valve.
Where can I locate Idle Air Control valve on the vehicle?
Look up under the intake manifold a couple inches to the passenger side of the starter.
Page 2 of 2 1 2
