CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by brapple: just remembered another way tot change the belt that I searched for or was told about on the old board.
cut just the front half of the old belt off, so that some of the belt is left to hold the cams and the timing. then slide the new belt on and cut the rest of the old belt off and then finish installing the new belt
that won't work....especially when you replace the tenisoner, pulley, and W/P.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 21,653 |
Originally posted by LoCoZ: Originally posted by brapple: just remembered another way tot change the belt that I searched for or was told about on the old board.
Which would be proper maintenance. And any car can come outta time and proper maintenance would be to check to make sure it's in time. It doesn't take all that much longer, so unless you're really lazy, there is no reason not to.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
