Page 4 of 5 1 2 3 4 5
I've got another idea. How crazy would you be willing to go? Would you be building the box?
APT Offline
Might as well spill the beans and let him think about it. It's amazing how your mind can convince yourself of the things you think you wouldn't typically do.
Yup, I'm building the box. What's your idea? I'd go as far as I can using a table saw.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
APT Offline
And a dril and jig saw. Cool!
9
9
I had the same priorities when building my system. I need my trunk space, but also wanted enough bass to satisfy me, just not overkill. Here is what I did and the seats still fold down.
The back of the seat is metal, at least on my 95, not sure about other model years. I used a spacer plate with 3/4" dense weatherstrip to seal the plate to the irregular surface of the seat back. I also cut the hole in the metal smaller than the surface area of the cone to give the sub some loading. This works well, if you do not have to have 140 db. I have a PPI 4200 amp running the entire system, and it is clean, tight, and loud enough for me. (high 120's)
One fifteen is probably around the same cost as 2 eights and more efficient.
Hope this helps.
-Scott
I'll build it out of 3/4" MDF, liquid nails, pillow stuffing, automotive grade carpeting, etc... the usual stuff.
It will be dual-chambered and be mounted to the bottom of the rear deck. It'll be about 6" tall and will span the width of trunk necessary to provide the box volume I need.
The amp will be mounted on the face of the box. The subs will be bottom mounted to allow for maximum clearance under the rear deck. I'll cut all of the corresponding holes in the rear deck sheet metal and dampen/brace as necessary.
Yup, it'll be in my SVT.
Space is definately an issue. I travel a lot and need the trunk space. I don't like sub boxes rolling around in the trunk, and I don't want to lose any floorspace. I also don't want to make my folding down rear seats useless. I'll also mount the amp on the face of the box, so everything will be nice, neat, and tucked out of the way and still easily accessible. Also, I'd prefer subs firing into the cabin as opposed to trunk. I'm into efficiency and don't want to get into overkill to provide my system with some much-lacking thump.
I'm looking into 8" sub(s) as 10s require more space (box volume) and are slightly too big in diameter to fit into the configuration I'm contemplating.
You've got some ideas that are more off the wall than this one??????
[This message has been edited by 95TealSE (edited May 04, 2001).]
APT Offline
The drivers he's looking at are cheap at <$50. Heck, that sold out one would have been perfect for him at only $20ea.
BTW, nice setup, Scott! The only problem I see is loose cargo ramming into the driver and poking a hole in it.
Hey Scott, nice setup.
I probably won't go with a 15. They're usually more efficient, but I prefer the sound of a smaller diameter sub. A 10 would be my first choice, but I'm trying to keep as much space trunk space as possible and an 8 will do the trick.
1999 SVT #900/2760
Born on 1-20-99
What subs are you guys talking about!?!?!?!?!!?
1999 SVT #900/2760
Born on 1-20-99
First, I'll try to desribe it, then i'll post a pic to help clarify things.
Here goes nothing....
The design i am thinking of would be an isobaric 4th order bandpass system using two tens and a passive radiator rather than a port. A table saw will help tremendously!!
i'll post a pic in a few minutes.
APT Offline
The sold out one is Parts Express #299-104.
Since they aren't showing the specs, I e-mailed them to Dave as they wer eprinted in a sales flyer sent out this week.
PE #299-104
PW8035DV Ultimate?
175w max
Z: 2x4ohms
Magnet weight 35oz
Fs: 38Hz
SPL 94dB/1w
Vas: .8 cu ft
Qts: .45
Qes: .56
Qms: 5.01
Xmax: 6.4mm
Size: A=8 1/8"; B= 7"; C=4"; D=4 3/4"
Dave is working on a design using #299-090 for you now, Colin. He drew me a pretty picture and it's quite a crazy design, but looks very rewarding.
[This message has been edited by APT CSVT (edited May 04, 2001).]
Moderated by  dnewma04_dup1
