Originally posted by dnewma04:
How do you plan on building this? What kind of car (your contour?) Is space a big issue? Why is an 8" the only option you are looking into? I just want to get a feel for what you are looking for and maybe i can offer something a little off the wall.
I'll build it out of 3/4" MDF, liquid nails, pillow stuffing, automotive grade carpeting, etc... the usual stuff.
It will be dual-chambered and be mounted to the bottom of the rear deck. It'll be about 6" tall and will span the width of trunk necessary to provide the box volume I need.
The amp will be mounted on the face of the box. The subs will be bottom mounted to allow for maximum clearance under the rear deck. I'll cut all of the corresponding holes in the rear deck sheet metal and dampen/brace as necessary.
Yup, it'll be in my SVT.
Space is definately an issue. I travel a lot and need the trunk space. I don't like sub boxes rolling around in the trunk, and I don't want to lose any floorspace. I also don't want to make my folding down rear seats useless. I'll also mount the amp on the face of the box, so everything will be nice, neat, and tucked out of the way and still easily accessible. Also, I'd prefer subs firing into the cabin as opposed to trunk. I'm into efficiency and don't want to get into overkill to provide my system with some much-lacking thump.
I'm looking into 8" sub(s) as 10s require more space (box volume) and are slightly too big in diameter to fit into the configuration I'm contemplating.
You've got some ideas that are more off the wall than this one??????
