#753414 09/22/03 03:44 PM
I wanat to run my amp to my speakers for more power. my question is shoudl i run speaker wire form each speker into the amp. Witch is apain in the ass cuz i gotta rmeove all the door panels. Or is there a way to hook the wires up for the amp rite into the speaker wires were the radio goes. my friend mentioned this were not sure if it will work?????
99 Silver frost Contour LX ztec..(RIP March 24th 2004 at 92,376 miles ) timing belt snaped goin 45 New whip 2003 Silver Mustang
#753415 09/22/03 05:09 PM
Well, i dont' think you can do that.
The way it's wired up now is that your HU has the pre-outs and it has it's own amp(45x4 or something like that) Well, the speakers are hooked up to the HU's amp. Now your going to be using an external amp. So the HU's preouts go to the amp, then speaker wire from the amps channels to your speakers. You will have to remove the door panels for the door speakers. I haven't wired my speakers to my amp yet BUT i have replaced my stockers in the front. The door panels aren't difficult to remove, you could hook up your speakers in probably 1 - 2 hours, depending on how much trouble the screws gives you.
Click to see how to remove door panels
Make sense?
You could probably run the speaker wire and splice into the wiring from the HU but....I'm not sure if it's a good idea. It could be. I'm not going to do that though. Not worth it to me, plus, I've already got a splicing mess back there
96 Contour LX ATX Clarion DB625MP 2 "5x7" infinity kappa's in front 2 stockers in back 1 JBL GT 1200D 12' 1 jensen xa2150 pushing the sub *upgrades comin soon
#753416 09/22/03 06:39 PM
2
OK let me see if I can decode this:
You have an aftermarker HU and you want to add an aftermarket amplifier to power your aftermarket speakers without running new wire to your speakers?
A few questions:
-How many sets of preouts does your HU have? I am assuming one set is being used for your subwoofer amp. Model numbers for HU and amplifier you plan to add would help.
'01 Escape XLT V6 on S100 CDT Audio/Ascendant Audio/Rockford/JBL/Knukonceptz setup '00 SE Sport ATX
#753417 09/22/03 08:32 PM
I have a sony xplod CDX-M600
amp im using a 2 channel fosgate or a 2 channnel xpold...
Moderated by  dnewma04_dup1
