Page 1 of 7 1 2 3 4 5 6 7
#752425 09/21/03 07:06 AM
ok just wondering cuz i think my car is getting terrible mileage. For combined driving i get anywhere from 18-23 and thats mostly highway too. i think these numbers are very bad considering i have all the mods listed below. And no i dont rev it high i normally keep it below 3 and it shifts around 2000-3100. So im just wondering WTF is the deal?? i have replaced the fuel filter already and the plugs so its not those and have rebuilt the intakes so thats not it. Any suggestions would be very helpful considering just tonight i have around 200 miles on the trip and a 1/4 tank of gas left
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#752426 09/21/03 02:47 PM
Z
Z
v6 or i4 ?
#752427 09/21/03 03:07 PM
V6
#752428 09/21/03 09:21 PM
that sounds about right... 200miles w/ a qtr tank left. thats what i get. Our tanks are if i'm not mistaken 14 gallons, when you fill up (i fill up at around 240 miles) thats just flirting with the gas light coming on, i usually have 2 gallons STILL in the car because i usually end up paying for 12 gallons. so instead of dividing your total mileage by 14 (the size of our tanks), divide by 12 and that should give your a smoother, not so rough estimate.
Jeff Silva E0 Contour SVT Silver -STEEDA PEDALS -K&N Drop In -Ford Racing Wires (w/Bosch +2's) -Cleared Headlights -Yokohama AVS ES100's -Alpine CDA7893 w/MBQuartz -EUROLITE 9006/893
#752429 09/21/03 09:24 PM
I get 25MPG Avg (over 35K miles). Lows are 19-20 (winter, highest is 34 MPG on 400+ mile trips.
I track all my costs as I use the car for work.
Interestingly, the 34 MPG was on trips to Pittsburgh and Charleston, WV. and I was traveling in the 80 MPH range most of the trips (just keeping up with the tractor trailors). The car does like high speeds.
The only performance mod is a drop-in K&N Filter. I keep the tires (Falken Z-502 205-60 HR15) at the sidewall max pressure of 44PSI. Rides a little hard, but handles well and doesn't mind rain.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#752430 09/21/03 09:48 PM
i usually get 240-280 miles out of a tank of gas. And that's with the air running non stop in the summer.
Tony Datsenko
#752431 09/21/03 10:19 PM
With a 14.6 gallon tank, that's only 17-20 MPG if you ran to empty.
An MTX should do better than an ATX (or not).
How much gas does a "Tank" mean? 10 gal= 24-28 MPG, 12gal means 20 to 23 MPG.
#752432 09/21/03 10:24 PM
I once got 46 mpg coming back from Vegas at 65 mph but I usually get 40-43 on the same route.This is with a 4 cylinder engine and standard transmission using premium fuel.I also use Mobil-1 oil which reduces friction.The worst I got was 39 mpg at 70-75 mph and a headwind.
#752433 09/21/03 10:33 PM
um, i ussually get 10-12 gallons when i fill up.
Tony Datsenko
#752434 09/21/03 10:50 PM
9
Best ever was this summer after doing the y-pipe mod and K/N filter in the airbox,41 mpg. The y-pipe mod
is worth every cent it cost to do it !!!!
Edit: Equivalent to 34 miles/US gal. Presumably hwy considering location
96 contour SE,E1 rims w 205/60/15 Comp TA's VR4's,optimized y-pipe,SVT doorsills,KKM intake,BULLIT MUSTANG fuel door,painted grill,every available option w/leather ! 95 mystique LS,every option minus leather,optimized y-pipe+exhaust
