#751967 09/20/03 09:45 AM
js139 Offline OP
I have recently been having a problem with my 2000 SVT. I was driving down to the fair and the front end began to vibrate. Vibrate may even be to soft of a word. Maybe Shutter is more like it. It felt as if i was going over small washboards on a dirt road. Keep in mind, this was a newly paved interstate. This isn't the first time i have noticed it, but it was alot worse tonight. It only seems to do it at speeds between 60-70 mph. If i speed up or slow down out of that speed range, it is smooth as a baby. I am thinking it is something simple like maybe an out of balance tire, but i am not sure. Anyone out there come acrost this problem at all?
Jeremy Plank Black 2000 SVT Born on 12/14/1999 #926 of 2150 Tinted windows, CEG Decal b&m(shortly), Rear SVT BAdge Painted grilles,pre98 sail panels, Kenwood KDC-X859 MP3 deck Kenwood MP3 Changer, Infinity Basslink New Motegi FF5s Hyperblack
#751968 09/20/03 01:04 PM
Engine mount or Trans. mount....
Roland 98 SvT WiTh StUfF...Sold Evo 8
#751969 09/20/03 01:50 PM
If your lucky, might just be a tire out of balance. You might have thown a wheel weight. The symptoms would be worse within a certain speed range, which seems to go along with your description. Also could be a shifted or bad tire belt. (It does happen.) If belt replace tire ASAP.
Former, now returned CEG'er! 95SE MTX, (AKA "The Road Rat"). Stock except for:TH fix, B.A.T. big brake kit, tranny cocktail and lots of re-insulated wiring! May yet be a 3.0! "Speed doesn't kill, stupidity does!"
#751970 09/20/03 10:09 PM
js139 Offline OP
I know it isn't an engine mount because i can put the car in nuetral and let it roll, and it is still doing it even when it isn't under power. i'm taking it in monday and having them look at the tires. Anyone else have any other ideas?
#751971 09/22/03 12:38 AM
Please post the if the tires or something else fixes your pboblem. I've had the same symptom for a long time now (60-70mph). I've had the tires changed (worn out, not because of the vibration), then the new set was rotated, and I even had a set of snow tires. The problem has always been there. Never thought it would be a trans or engine mount. I just thought it's a half shaft or rotor something. But in the meantime I've had all 4 rotors replaced so that's not it. It runs fine otherwise, so I haven't spent money trying to chase it down. I'd be interested in knowing your result.
Andy
Andy 96 Contour V6 101000 miles
#751972 09/22/03 01:57 AM
may be a bent rim. if none of the mentioned stuff has fixed it. if your steering wheel shakes, rotate your tires front to back and see if it still shakes the steering wheel. that way you can also narrow down if it is a rim and where it is.
#751973 09/23/03 12:49 AM
js139 Offline OP
sounds good. i will give it a shot
#751974 09/23/03 02:36 PM
I have this exact same problem in my '95 Contour GL. On the freeway between 65-70 the front end and steering wheel begin to shake. Goes away under 65.
I thought either tire, wheel, or maybe ball joints. Haven't done anything about it yet though. When I had it jacked up the other day I checked the wheel for play, and while it had a little bit it didn't seem totally shaky or sloppy so maybe ball joints are okay.
1995 Contour GL "GEX" 2.0 Liter 4-banger ATX 162,500 miles Stock except for two '89 Tempo wheel covers & two VERY COOL cosmic looking '76 Toyota Corona wheel cover Full size spare No rust Green Purchase price: $500
#751975 09/23/03 02:51 PM
Yeap. Yesterday did a long trip and had the same problem but on my rear left wheel. It happens between 65 and 75 MPH. Really bad shake.
Pablo Quintana 98 SE Sport Contour Honduras, Central America
#751976 09/24/03 05:15 AM
i having the same problem as well. it feels like my front end is about to fall apart. ive balanced and rotated tires but it never seems to go away. i thought it may be b/c i dumped the car about 2+ inches and the struts cant handle it. if anyone can come up w/any answers pls email me at jlpottle@comcast.net
00 Toreador Red SVT-#1751 of 2150 KKM intake No resonator Eibach springs 2 1/2" drop No door ding guards Side markers
