okay!The hub assembly has to be removed in order to replace
the bearings.what he should of said was it should be replaced with the bearing because you have to remove it
first.but....you don,t have to replace the hub.I have 16
years of experience and I can tell you that the mechanic
is covering his a$$.before you replace them make sure you
check the lower control arm bushings,ball joints and Tie
rod ends.you can save alot of time and money because you
can service these parts at the same time.I have my own
bearing press made by OTC and this will allow you to
press the bearing out and on to the car.its takes a few
hours with hand tools.I hope this will help you
New Pics of OUTKAST 1!Sept2006
