Ok, so I've got 2 amps, a 2 channel jensen 150x2 and 4 ohms with the pass through option. I've also got a rockford fostgate 4 channel amp with the two rca inputs of course. So i figure i'll just run my infinity 5x7's off of 2 channels and run the DVC 12 sub off the other two channels and i'll daisy chaing the jensen and the fostgate. Oh and the fostage doesn't have a fuse on it but the jensen does. I ended up running 4ga into a fused distro block (30 amps each) which splits into 2 8ga's. Those powered the amps. Also ran two 8ga into a distro block which goes into 1 4 which is the ground. well When i hooked everything up, including remote turn ons, not everything worked peachy. The jensen was not turning on but the RF amp was. The remote turn on's are coming from a 7band EQ up front so this leads me to believe that the set of RCA's going straight to the fostgate turned the amp on. I did not however get sound when i wired up the subs to the side of the amp. I'm quite confused and this garbled write up probably doesn't help but if you weed through it, please give me a heads up...I've check all voltages and everything checks.
96 Contour LX ATX Clarion DB625MP 2 "5x7" infinity kappa's in front 2 stockers in back 1 JBL GT 1200D 12' 1 jensen xa2150 pushing the sub *upgrades comin soon
If it helps, the remote turn on voltages are only about 8 volts....I think somewhere I read that they need to be between 10 and 15....right?
I give up, i can't find the problem. When I hook up just one amp to the remote, it shows 12v, same with power. But the amp doesn't turn on. I'm officially lost. VOltages up front check out too.
help, anyone, plz?
Moderated by  dnewma04_dup1
