Posts: 2 |
I recently purchased a new set of Bosch Platinum plugs for my '98 GL to replace the Motorcraft Platinum already in my engine. The problem is that I can't get them to thread. Autozone verified that I was given the correct part # (#4205). I spoke w/ a guy with SP Motorsports that told me I needed the Bosch Platinum +4's (#4458) and that I was given the wrong ones. I was able to remove and re-install the old ones easily. Is the problem with the threads or do I have the wrong plugs? Are the +4's really worth $5 ea.? Aron
Posts: 4,714 |
Duratec engines require double platinum plugs, so stick with Motorcraft or Autolite plugs. The Bosch +4's are very hit-or-miss, and many people have reported problems after switching. The Autolite part number is APP764; I paid $3.99 each at Checker Auto (or Kragen or Schucks or Advance or CSK... all the same thing).
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 2,408 |
Welcome to CEG!
Be very carefull not to strip the heads!
Stick with Motorcraft or Autolite double platinum plugs as hetfield says.
Posts: 95 |
we don't even use bosch plugs in our mondies we have NGK the best you can get (don't know if they sell them over their
Posts: 2,779 |
i don't know about the best you can get....but ok.
Posts: 71 |
For several months now I have been using Bosch paltinum plugs. Regular stuff, not 4+. So far no problems. I will keep an eye on them for the following months just to be on the safe side. NGK's are really expensive here (like 65$ for a set of six) and hard to come buy. We have Ford dealership coming to Sarajevo this fall so maybe I can get some Motorcraft (I gues I can order it too but I am being lazy) just to be sure. I firmly believe in OEM for a non-moded engine. If one does the mods, well everything is a fair game then.
airman1
Black '95 Mondeo
V6Si
Posts: 429 |
I have been using the same Bosch +4s for the past 52,000 miles. Took them out for inspection a few weeks age and they still look very good. Engine performance is still very good as well as mileage. I will certainly consider another set come change time!
Dan B.
96 SE 2.5 auto
Posts: 183 |
I just got the NGK plats today, have not put in yet, but they were 40ish or like 6 something per plug. hopefully they worth it  -Daniel
99 Contour SVT
-Spec Stage 1 Clutch, LSD, Spec lightened flywheel.
91 Ranger XLT
Posts: 1,254 |
i run the autolite plats, but on my old probe i ran NGK for its whole life, ran like a champ. never had problems with either. from what i understand, NGK's are mainly for imports.  <----new?
