Originally posted by dnewma04:
Rollingstash,
You have to remember that MTX uses two ratings, first RMS power with a 12.5v source. The second is rated in dynamic (also referred to as max power) power with @14.4 volts. Basically, what i'm trying to say is that the MTX is more like 165-170 watts RMS when powered with a 14.4v source.
I don't believe that MTX is referring to peak/max power when rating their amps at 14.4 volts.
I think that the "dynamic" term is referring to the potential RMS rating when the amp could receive a steady 14.4 volts. With other accessories running, changes in engine rpm, etc... the amp usually won't see that steady 14.4 volts. However, it should receive a steady 12.5 volts from the battery at all times (barring mechanical difficulties of course). Hence, the rms and dynamic ratings (as I understand them).
Also, I don't think that MTX uses peak/max power ratings for their amps. BTW, I consider peak/max power to be an absolutely useless measure.
If you REALLY want to know what an MTX amp is putting out, you need to look at its birth certificate.
My PRO502 was putting out considerably more than what it was rated at with THD<.005% too.
